Old 07-26-2011, 02:23 PM
Mark and Poco is on a distinguished road
Fanuc 0M Batch Loading Programs
Ok here is an interesting problem for all you Fanuc experts. We have over 20 Fanuc Robodrills, but recentluy aquired a brand new feelers/methods with a 0m controller. The problem we are having is when trying to load a series of programs from a CF memory card, the machine renumbers all the sub programs, and does not change the M98 O**** in the main program. Does anyone have any Idea on how to batch load these machines, or is there a parameter in the 0 controller that is defaulting this.
If we were only dealing with 1 main program and a few subs, it wouldn't be a problem, but the job these machines were bought for have on average 80 sub programs. Again thanks for any help or insite anyone may provide.
Old 07-26-2011, 06:43 PM
Dan Fritz is on a distinguished road
Do your subs have O-numbers in them? If so, do the O-numbers coincide with the file numbers on the card?
Old 07-26-2011, 10:58 PM
dcoupar's Avatar
0M what? 0iM-C? 0iM-D?
Old 07-27-2011, 07:05 AM
All the sub programs have Oxxxx numbers. These are running programs on RoboDrills. as for the model it is a FANUC 0i-MD
Old 07-27-2011, 07:17 AM
So let me get this straight ... The sub programs on the memory card have O-numbers in them, but the machine gives them new, different O-numbers when it loads them into memory ??
Old 07-27-2011, 07:38 AM
yes, it renumbers them in sequential order based on the main program number. If the main program is 05000 for example, every sub it loads after that is sequentially numbered O5001, O5002, O5003 etc.
I know it sounds weird, but it is happening. An initial call to feelers/methods had no answer, they sugested loading each individually, that's why I'm asking here.
Just wondering if anyone has seen it, or heard of it, and hopefully has a work around or solution for it.
Old 07-27-2011, 07:52 AM
dcoupar's Avatar
Are you using O-SET to specify the main program O-number? If so, leave O-SET blank.
Name:	0iM-D Batch Input.jpg‎
Old 07-27-2011, 08:53 AM
OK will give it a try. Thanks
Old 07-27-2011, 09:12 AM
That looks like what we need. Just wondering if you would be able to send me the whole page and the preceding page so I know where to look to change it to work. Or some step by step directions would be great also. Thanks Again. "This place is better then tech support."
Old 07-27-2011, 10:26 AM
Got it, Thanks for all the help. I really appriciate it. Thanks again
  #11   Ban this user!
Old 07-27-2011, 10:39 PM
dcoupar's Avatar
Glad I could help.
  #12   Ban this user!
Old 07-28-2011, 09:29 AM
Thanks dcoupar,
That was a new one to me too.
Dan
Need Help!- Saving/Loading programs on a 6M? QUALMACH1 Fanuc 2 01-19-2011 10:27 AM
Need Help!- Loading programs on R2E3 TWKundrat Bridgeport and Hardinge Mills 1 04-21-2009 04:49 PM
Need Help!- Loading programs in a Fanuc 10M Chappyd Fanuc 5 11-10-2008 12:46 PM
Loading offsets with programs GITRDUN Haas Mills 34 09-06-2007 10:56 AM
loading programs into dos bkstout General CNC (Mill and Lathe) Control Software (NC) 7 02-12-2006 08:05 PM
