Old 07-23-2011, 06:31 PM
gogego is on a distinguished road
I could use an assit creating variable program
We have a sl 25 mf-t6 I think, Fanuc control, I want to try some conditional programming, IFs and GOTOs and such I have the prog and op manual here with me but cannot pinpoint this topic, is it in the FANUC book Ileft at work?
I think the machine was purchased new in the mid 90's not entirely sure which version FANUC we have , our FANUC book has 16 18 on the cover...
Can anyone give me the proper format for IF/GOTO statements
ie
G0Z.2
X[#100] Z.1
G71U.150
G71P21Q22U.02W.005F.014
N21G0X[#101]Z.05
G01Z-[#107]
?? IF [#102 EQ 0] N22
X[#102]
Z-[#107+#108]
?? IF [#103 EQ 0] N22
blah blah blah
N22X[#100]
IS THIS ON THE RIGHT TRACK?
I'm just a butcher masquerading as a machinist
Old 07-23-2011, 08:46 PM
Dan Fritz is on a distinguished road
G0Z.2
X[#100] Z.1
G71U.150
N21G0X[#101]Z.05
G01Z-[#107]
IF [#102 EQ 0] GOTO22
X[#102]
Z-[#107+#108]
IF [#103 EQ 0] GOTO22
blah blah blah
N22X[#100]
Old 07-23-2011, 08:53 PM
christinandavid's Avatar
christinandavid is on a distinguished road
IF[#102EQ0] GOTO22
EQ is equal to
NE not equal to
LT less than
GT greater than
LE less than or equal to
GE greater than or equal to
If you want to combine conditional statements: -
IF[[#102EQ0]AND[#103EQ0]] GOTO22
AND, OR, XOR
DP
ps if I can find a mathematical approach that eliminates logic/program branching, I do it!
Old 07-23-2011, 09:51 PM
Good deal I appreciate the feedback, it looks like I just grabbed the wrong manuals I will get the FANUC book tom. when I try to finalize this litle program.
Cheers!
Old 07-27-2011, 03:48 AM
sinha_nsit is on a distinguished road
see the attachment for more details about IF_GOTO_ statements.
Old 07-29-2011, 05:33 AM
CNC Data's Avatar
CNC Data is on a distinguished road
Hello.
I have written a simple Macro B PC Desktop Application to find variables and a Macro B programming manual. Both are available to download free from CNC Data Limited :: CNC Data Monitoring and Collection under the downloads section.
Hope this helps.
CNC Data Ltd
www.cncdata.co.uk
Old 07-29-2011, 01:10 PM
ad64075 is on a distinguished road
Aparently everyone who commented thus far failed to actually think about what your program is doing. You CAN NOT use conditional statements within a roughing/finishing cycle (G71).
There are numerous other ways to make a variable program work while still using a canned cycle, for example using incremental programming within the cycle. If you do not want a certain move made, the variables corresponding with that feature would equal zerom therefore when the machine read U0. V0. W0. etc., it simply would continue to the next program line without axis movement.
Hopefully I shed a small bit of light onto your problem. I have wrote countless variable programs for Fanuc controlled lathes, for simple to highly complex including 3 axis live-tooling work. It's not impossible. Nothing is. You just need a little shove in the right direction sometimes.
Need some direction creating variable prog. gogego Mori lathes 1 08-02-2011 01:29 PM
Outputting Common variable values into a program (with automated program number) yaji63 Fanuc 0 12-27-2010 02:55 AM
Creating Sub Program In Genises bri008 CNC Machining Centers 7 09-08-2009 05:58 AM
Need Help!- variable program caddisfly Fadal 16 08-31-2009 11:05 AM
help creating program brockadeau Mechanical Calculations/Engineering Design 1 11-16-2007 08:01 PM
