Old 07-21-2011, 06:33 AM
sinha_nsit is on a distinguished road
What does G stand for in G-code?
This is an old question, with no answer so far (or I am not aware).
Any idea?
Old 07-21-2011, 07:26 AM
Dan Fritz is on a distinguished road
I'm not certain, but I seem to recall that it meant "General".
Old 07-21-2011, 08:17 AM
G = General code.
M = Miscellaneous code.
According to books I have read.
Old 07-21-2011, 10:41 AM
underthetire is on a distinguished road
G=Gosh dammit, just ran in to the table again
M=My, that was strange.
Old 07-21-2011, 11:53 AM
frank12933 is on a distinguished road
Geometry
Old 07-21-2011, 02:33 PM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
General Function
Old 07-21-2011, 07:09 PM
Ron Dunn is on a distinguished road
Gyneacological.
(because it is a **** of a language)
Old 07-21-2011, 07:51 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Gobbledygook.
Old 07-21-2011, 09:42 PM
Rich L is on a distinguished road
Go take a look at:
LinuxCNC.org - G Code Overview
excerpt:
" ... The EMC2 G Code language is based on the RS274/NGC language. The G Code language is based on lines of code. Each line (also called a "block") may include commands to do several different things. Lines of code may be collected in a file to make a program.
A typical line of code consists of an optional line number at the beginning followed by one or more "words". A word consists of a letter followed by a number (or something that evaluates to a number). A word may either give a command or provide an argument to a command. For example, "G1 X3" is a valid line of code with two words. "G1" is a command meaning "move in a straight line at the programmed feed rate to the programmed end point", and "X3" provides an argument value (the value of X should be 3 at the end of the move). Most EMC2 G Code commands start with either G or M (for General and Miscellaneous). The words for these commands are called "G codes" and "M codes." ... "
Admittedly, it does look like gobbledygook but I'd probably argue against any clinical abstractions.
Cheers,
Rich
What does NFR stand for? leeputman General Metalwork Discussion 5 12-17-2010 07:24 PM
Need Help!- What does VDI stand for? leeputman CNC Tooling 3 10-06-2010 12:01 PM
KX3 and Stand dfmiller Benchtop Machines 9 01-01-2009 12:01 AM
So what does TLO stand for? CNCadmin FAQ of CNC Machine building 0 10-23-2004 05:07 PM
What does DRO stand for ? ynneb FAQ of CNC Machine building 0 08-16-2004 10:13 PM
