Results 1 to 9 of 9
Thread: Fanuc threading parameters
    Jul 2011
    I have a YCI TC26 with a Fanuc 21I. Can anyone tell me what parameter sets the automatic retract angle in a threading cycle.
    Registered dcoupar's Avatar
    Mar 2003
    If you're referring to the chamfer-out at the end of each pass, according to the manual, the angle is "approximately 45 degrees", and I'm pretty sure it's not adjustable by parameter.
    Feb 2006
    india
    You can only change chamfer distance.
    Jul 2011
    Hey i found the paramiter, it is 1530 you can't change the angle, but you can change the size. i set it to 0 and it worked great! i believe it only changes G76 and G92 threading cycles.
    Feb 2006
    india
    In G76, chamfer distance can be explicitly specified, which, I believe, would override this parameter. (Incidently, it is 5130)
    There is a parameter 5131 also for chamfering angle, but I have never tested it.
    It is generally believed that the angle is not adjustable. Somebody may please check and report the finding.
    Mar 2003
    Quote Originally Posted by sinha_nsit View Post
    My mistake. Parameter 5131 is not listed in the 21T parameter manual, but is in the 21i-T parameter manual.
    Feb 2006
    india
    Actually, this is a mistake perpetuated by Fanuc. Even i-series operator's manual says that the angle is approximately 45 degree. I also believed this until I saw parameter 5131, accidently.
    It is a fact that even though Fanuc does take care to enhance the software/hardware capabilities of their products, they do not always incorporate the changes/enhancements in their manuals. Only paramater manual remains updated.
    Jul 2010
    U.S.A.
    Type 1 or Type 2 programming? If you don't know redily, does your machine require 2 lines to begin a canned cycle, for example:
    G76 P010060
    G76 X1.500 Z-1.5.........
    Jul 2011
    Only needs one line to star canned cycles.
    1. fanuc OT threading problem
      By prash in forum General Metal Working Machines
      Last Post: 10-21-2010, 10:40 PM
    2. Need Help!- Threading G76 on Fanuc 5T
      By RGeo in forum G-Code Programing
      Last Post: 06-25-2010, 12:29 AM
    3. Fanuc 10T Threading
      By SGARCIAM in forum Fanuc
      Last Post: 02-04-2009, 02:00 PM
    4. Fanuc 11T threading?
      By rai in forum Fanuc
      Last Post: 05-13-2007, 09:29 PM
    5. taper threading using G76 on Fanuc OT
      By sinha_nsit in forum Fanuc
      Last Post: 03-23-2006, 05:31 AM
