Old 07-19-2011, 09:53 AM
ahmed4040 is on a distinguished road
X axis vibrztion
Dear All
We have a machining center with Fanuc 0imc controller, the problem is :
When we make zero return for X axis, some vibration happens at the end of the stroke (when the X axis reach its zero position).
This strange vibration happens in handle mode and ZRN and all modes.
The bearing and backlash are ok.
what shall be the reason for this problem
Old 07-21-2011, 04:22 AM
i think the vibration is coming from motor & coupling side.
any help please !!!
Problem- a problem with slaved A-axis moving properly relative to Y-axis zool Mach Software (ArtSoft software) 34 07-05-2011 09:45 PM
Need Help!- X axis works fine but Y axis direction is erratic swampbud1 DIY-CNC Router Table Machines 4 12-06-2010 05:28 PM
Grinding and unexpected axis movement if rapiding 2 axis DarkSabre Taig Mills & Lathes 4 03-25-2010 11:37 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
