Having a problem with my old Kitamura VMC DC spindle motor and/or drive. Machine: 1981 Kitamura Mycenter-2Scenario: Was running an easy cutting UHMW job when machine shut down.History: I have cleaned/inspected the brushes about 6 months ago and they were dusty with carbon dust but not out of the norm. I polished/cleaned the commutator and inspected for any bridging. I do this fairly routinely.Actions so far: Pulled the motor, disassembled and cleaned everything. Turned the armature and scraped the arm. slots. Replaced bearings while torn down.Kitamura tech says that the 401 error combined with the copper dust on the brushes indicates that motor will need rebuilt. The rebuild cost is enough that it may be time to part ways with the machine. One thing that I notice and do not recall before. The EMG relay LED is lit as soon as the power is turned on. Is this indicating that there is an emergency stop situation?? I have cycled the Estop button and made sure the toolchanger was at home positions. Thanks...Bob |
| You blew fuses before, but did you check the SCRs? If an SCR is blown, it will take out a fuse as soon as you try to run the spindle. Also, make sure that your spindle drive is getting 3-phase current. If one leg is out and your "single phasing", that would create trouble too. |
| Also did you Megger the brush holders to ground, often tracking is a problem that does not show up with low voltage ohmeter. I have the same scenario with DC servo's. Al.
Just checked that today (...forgot to check before). I'm only getting about 3 ohms resistance on the field windings. Does that sound low??
The drive is getting 207-195-196 VAC I tore the motor back off and it's strapped to a pallet ready for the motor shop to evaluate. I have a customer who relies on me for his product delivery, so need to get back up and running in a week or 2. (OTOH, borrowed a neighboring shops new Haas VM-3 and finished the current batch of parts in 30% my normal time....hmmmm) Thanks for the replies so far. |
Dan, I (finally) checked the 12 SCRs and looks like one is shorted closed. The p/n is NEC 25P8SG which I can't seem to find anywhere on the net. I can call Fanucworld or other Fanuc sources to inquire on replacements. Is there a substitute for this p/n? Should I replace all 12? Thanks Bob |
| You might possibly to get away with changing an SCR from the opposing bank, 6 are used for each direction (FWD/REV), it is worth a try and just leave the open spot unconnected. Al.
| Need Help!- Fanuc O-Tc AC Spindle Motor Drive Problem | suleman_mani | Fanuc | 3 | 10-28-2008 08:28 PM |
| 1981 KITAMURA Mycenter 2 trigger output | moldmker | Fanuc | 4 | 06-28-2008 04:02 PM |
| 1981 Kitamura Mycenter 2 w/Fanuc 6M-B Spindle Problem | TFGC | Fanuc | 6 | 05-27-2007 09:50 PM |
| 1981 Kitamura M-2 Fanuc 6M-B YZ Simultaneous Movement | TFGC | Fanuc | 16 | 01-07-2007 08:16 PM |
| Kitamura 3xi w/ Fanuc 16i Alarm problem | thamain1 | Fanuc | 2 | 09-08-2006 03:03 AM |
