Its on the keypad of every 21 I've seen. It was shift>something on the number pad. All our machines are newer, so I can't just go look.
I need the square brackets for a macro I'm writing but I'm getting a parenthesis instead. I believe I have to change a parameter but I can't find any mention of it in the manual. The machine is a Hardinge Cobra 42.
underthetire -
I have the "small" keypad so parentheses and brackets use the same button.
Bit 0 did the trick! Thanks for the help.
