Old 07-12-2011, 06:29 PM
hotrob1 is on a distinguished road
Fanuc 16-TT metric to standard
We have a Fanuc 16-TT and we are trying to change mm to inches. According to the info I have it is parameter 0000 bit #2 INI. We now have a "0" which is metric and it needs to be a "1" for inches. I have changed the PWE to enable but cannot get the bit changed. How do I change from mm to inches on a Fanuc 16-TT???
Machine is down so any help will be greatly appreciated!
Thanks in advance. The only manual I have is the operator's manual for series 16.
Old 07-12-2011, 07:25 PM
Offset setting
I also tried changing it in the "offset setting" under input unit. What do you mean by password? I know what a password is, but can you give a better description or step by step? Thank you.
Old 07-12-2011, 07:42 PM
Dan Fritz is on a distinguished road
Have you tried entering a "G21" in MDI mode? That should change the input unit from inch to metric, and also the position displays.
Old 07-12-2011, 07:53 PM
What screen?
Thanks Dan. What screen do I need to be in to do that? I selected MDI mode and enter G21 under program. Is that correct?
Old 07-12-2011, 08:04 PM
underthetire is on a distinguished road
You should be able to just change it in the setting page. Remember you need to be in mdi to do it.
Old 07-12-2011, 09:16 PM
Parameter 1004
I had to change parameter 1004, bit 0 to 1 before it let me do anything. Thanks all!!!
Metric and Standard on the same machine upnorth Mach Mill 1 07-07-2011 04:44 PM
How to change Fanuc 10tf from metric to standard? blakemachine Fanuc 8 02-27-2011 10:54 PM
Changing blueprints between metric and standard.... Redfinger General Metalwork Discussion 11 09-29-2009 10:10 AM
Problem- Threading Standard/Metric Bill308 General Metalwork Discussion 6 02-06-2009 05:22 PM
Standard tapping and Metric Programming. Dull Tool General Metalwork Discussion 3 02-01-2007 04:09 PM
