Old 07-09-2011, 06:16 PM
kmcmillen571 is on a distinguished road
Fanuc O-TT will only run program with rapid in setup mode
I'd first like to thank Memeoryman for trying to find a way to get my one lathe to accept parameters as written in my first post.
Ok, I got another one of my 3 Wasino SS-8 lathes working but for some reason it will only run a program if the rapid is set in setup mode. As soon as I change it during the program, the program stops and when I switch back setup, i can press start and the program will continue. It won't work at the start of a program either unless it's in setup.
Also, I keep getting 434 and 444 axis detect alarm or something like that, (3rd and 4th axis for the robot loader). As soon as I unplug the 2 cables on the servo amp and plug them back in the alarm goes away
Any suggestions to fix these problems would be great. Thanks,
Kevin
Old 07-09-2011, 08:40 PM
memoryman is on a distinguished road
Sorry, Kevin. Should have given you my home number. Still no call about the option param problem Will try again Monday. I should be able to come Tuesday.
Bill
Old 07-09-2011, 08:52 PM
Bill
No need to apologize, that was an honest thanks for the effort you've put in to trying to solve one of my many machine problems lol. I'll talk to you on Monday. Time for me to take a holiday tomorrow and check out the Indy in Toronto.
Old 07-13-2011, 08:32 AM
L. Sakthivel is on a distinguished road
Dear Memoryman
I need the procedure to enter the Parameter in Fanuc oTT system
L. Sakthivel
Email:info@premierengrs.com, website:www.premierengrs.com
Override rapid feed rate in program? donl517 Fadal 5 09-18-2009 12:36 PM
Problem- no part program apears in dnc mode YOO Fanuc 3 04-14-2009 08:12 AM
What is - Torque Mode? Position Mode? Speed/Velocity Mode? sunmix Servo Motors and Drives 25 10-26-2008 03:53 AM
Newbie- Rapid height? Basic router setup help Ranscon WoodWorking 5 10-14-2008 07:29 PM
fanuc 21-I no 100% rapid bman356 Fanuc 5 09-29-2008 07:23 AM
