good morning Finally I have the parameters that were deleted I have another problem try to explain when you run the program in automatic I just read the first row but only that it does not move or when you type a command in MDI M3 S500 moves the spindle reviewed on the screen to verify if there are the 500 RPM and if they are but the command is not deleted I have no alamra any of you had this problem? who can help me out of the regards |
| good morning porblema was that the parameters are erased were loaded on a machine similar everything works if you recognize the zeros of the axes only when you run the program not moving remains in the first row type a command in MDI and function is met physically but not deleted from the screen as shown in the picture the spindle are working a review of the diagnoses 300 to 5xx are all zero not know if this is what this occasions the porblema try to modify the diagnostic but could not do comments are welcome WASINO LG-7 FANUC OT 0669-09 OMMOA3D-07 PMC-28T0-00 |
| thanks for the comment assumes that if you press star After putting the command in MDI is cleared after executing the command MDI M3 S100 pressing star command is executed spidnel is working on then clears the command screen without pressing reset key is supposed to be so? Sample Program G97 S4000 T0606 M04 G00 X5.8 Z.250 G01 X3.49 F.003 press star just run the first row others not that's the problem we have after that load the parameters that were deleted regards |
| MDI M3 S100 pressing star command is executed spidnel is working on then clears the command screen without pressing reset key is supposed to be so? YES G97 S4000 T0606 M04 G00 X5.8 Z.250 G01 X3.49 F.003 this program runs in MDI or AUTO ?? |
THIS PROGRAM IS AN EXAMPLE OF THE ORIGINAL G97 S4000 T0606 M04 G00 X5.8 Z.250 G01 X3.49 F.003 THESE ARE THE PROBLEMS THAT I HAVE I CAN NOT RUN ANY PROGRAM FOR THIS FAILURE I DO NOT KNOW IF I HAVE TO MODIFY SOME PARAMETERS OR SOMETHING MORE WORK TO CORRECTLY |
| Need Help!- wasino LG-7 / Fanuc OT (Need Parameters ) | dehoyosrobe | Fanuc | 0 | 06-29-2011 02:43 AM |
| Need Help!- Wasino WMC-3 Fanuc 0 MC | DHYSTA | Fanuc | 0 | 11-13-2008 10:39 AM |
| Need Help!- Wasino w/ Fanuc 3T control | kz1670 | Controller & Computer Solutions | 0 | 10-09-2008 10:16 PM |
| Wasino with Fanuc OM controler | 9566317 | Fanuc | 11 | 05-26-2005 12:42 AM |
