Machine - V.M.C. - KIA KV25 Control - Fanuc 0M The problem came out suddenly, without any change on machine/control. When machine starts to rigid tap, it immediately starts buzzing very loud. It makes few threads (aprox. 3 out of 10 on one workpiece), and than feed and spindle stop (at R level i assume), but it is still buzzing. When I push Reset button, buzzing stops. Buzzing is heard also when spindle doesn't rotate, between holes. Buzzing can be described as on very bad bearings. Buzzing is not heard when rotating with M3 at any speed. Spindle motor is connected to spindle directly, with hard connection. Rigid tapping, with same nc code (M29+G84) worked well before. Now if I replace M29 with M3, it works OK (without buzzing), but it is not rigid (synchronised) tapping now.
__________________ Sorry for bad english |
| Where this sensor should be, inside of the motor? Manual adjustment (moving) or with parameters? Maybe this could be seen in some parameter/diagnostic? 0M, I doubt. Tried, again same thing. I tried lower and higher RPM,and also changed feed. Buzzing is all the time the same.
| If it's the built in sensor, it should be on top of the spindle. It will have a fine pitch toothed wheel with a small pickup sensor. When those start to fail, or the adjustment gap is set wrong, the motor will buzz during rigid tap and orientation. Then you will start to get sensor alarms on the drive. |
- I don't get any alarms, since now (may be in the future) - during the orientation (M19), there is no buzzing heard "the adjustment gap is set wrong" That is in some parameter?
#10
| I haven't solved my problem because I didn't had any needs to make taping for last few months. Now I need this function so I tried something... I tried to adjust gap between sensor and toothed wheel. I reduced it, before it was from 0.10 to 0.15 mm and now it is from 0.05 to 0.07 mm. Nothing changed. I think it should not be less than that. Maybe it should be more, or less? Few notes: - I checked connectors and wires, everything seems OK. - Buzzing happens only in rigid tapping mode (M29 Sxxx + G84), M3/M4 works just fine - this start to happen suddenly, there were no problems with rigid tapping before some time (using the same program) - There are no alarms at all. - Mostly it does perform program (tapping)-ofcourse with buzzing, only rarely it stops in the middle of cycle and buzzing continues, and I have to push restart, but no alarms come out - M19 spindle orientation works fine. - Buzzing is heard also when spindle is stopped (at R level) - Buzzing is worse with lower RPMs (below 1500). - When I try with 2000 RPM or more there is no buzzing while tapping, just when starting and stopping of spindle (at R and at bottom). - when machine starts rigid tapping cycle and approaching R level, spindle is stopped, buzzing is present, and it vibrates (making small movements left/right, I feel it when I put finger on the spindle) - some time ago we have changed bearings of spindle PULSE GENERATOR A20B-9000-0500 AC SPINDLE MOTOR MODEL 2S, 8000 RPM A06B-0752-B190 SPINDLE PCB A16B-2201-0440/05B What to do next, just buy new pulse coder, or there is any way to check if it is bad? Thanks in advance for any help!
#12
| During this night I got another idea: Maybe encoder of Z axis is bad - giving non-constant position, and spindle tries to follow the Z axis....???
| tapping on a mini mill without rigid tapping??? | mls | Haas Mills | 13 | 07-03-2009 06:43 PM |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Tapping head or rigid tapping | Gregory_C | Syil Products | 2 | 10-18-2008 12:49 AM |
| Rigid Tapping | JIMMY | Mastercam | 9 | 09-19-2007 12:28 PM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
