Old 06-29-2011, 05:28 PM
maint_1 is on a distinguished road
409 torque alarm
16B control on a Makino A55E with twin screws on the Z axis. When I jog or command moves the currents on Z and W are well balanced. When I attempt a rapid to reference at a over ride greater then 1% it faults out. It will reference at one percent just very slow. When in rapid reference the current balance is way out. If Z is moving plus the Z current is positive while the W current is negative and quite high. In jog both currents match in level and polarity. Things I've tired, amp swap, synchronization procedure, ran on encoders scales off. Swap out Z motor with new, same, swapped out W motor same. Checked all machine parameters against a backup from a month ago and the only parameters different are 1860, which Fanuc tells me is just a register, and 8900. Neither parameter shows up in the parameter manual so they must be internal use. Feedback devices increment, scales are seeing their zero reference marks.
If I didn't know any better I'd swear the polarity of the motion command to W was reversed but given that they use fiber optics for the communicaiton to the NC that's not possible.
Any ideas?
Need Help!- Chiron X Axis Torque Alarm 409 Laig General Metal Working Machines 2 01-27-2012 08:54 AM
Need Help!- Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor? blakemachine Fanuc 1 11-11-2010 12:42 PM
Alarm 409-servo alarm- z axis torque alm jessebpm Hyundai Kia machine 3 06-14-2010 07:45 PM
X axis torque alarm on Takisawa Lathe lkenney General Metalwork Discussion 3 08-27-2009 02:14 PM
Puma 10S torque limiter alarm question fv74 Daewoo/Doosan 1 05-11-2007 03:13 AM
