I have a machine with FANUC control 11 which is in German. Does anyone have optional parameters for FANUC 10/11 or if someone knows the exactly parameters I would be grateful to him to send me on pm or write here on the forum. Thanks, Boban |
| Bill, The 9900 parameters are the ones starting at the 16 series control. The 11 series are 9100. I did a quick look and could not find any reference in the option parameters for language. Boban, I already posted in the other forum to your question and I will post here as well. I don't have the 11series manual but the 15 is very close. It should be parameter 2205.4 which is =1 for German. You will have to set to 0 and then set 2205.2 for english. Stevo |
| Thanks Stevo1. That should have been 9126 bit 6 for language:JAPANESE, ENGLISH, GERMAN, FRENCH, ITALIAN, SPANISH, SWEDISH. This is from Alpha4v1 database (GEfanuc database). It shows the same option for 15a, The option has to be turned on first. |
| Can you take a look at your ROM card I want know which software version in your CNC machine. You can read the name on your ROM chip Regards |
| Hi Today I succeeded in to switch the language to English. Parameter is 9126 bit 2 but I had to do a change in IPL Menu in hex format To change option parameters you have to load them in hex. Power up the control holding in the "-" and "." pushbuttons. This will bring up the IPL page Press 9 twice then input. This will bring up the option parameters. Press input until you get to the option 27 Enter the 4 then press input. Press input until you get to the end. Press 6 input. AND THAT'S IT THANK YOU ALL FOR YOUR ANSWERS! Boban |
| how to change my DSP language ? | Hamed | Chinese Machines | 6 | 06-14-2011 05:12 AM |
| change language of fanuc 6m | mohammad reza | Fanuc | 6 | 11-09-2009 08:18 AM |
| Change language of 21i-m | fomaz | Fanuc | 2 | 10-03-2009 01:14 AM |
| Need Help!- Mo Language change | greenery_fr | Mazak, Mitsubishi, Mazatrol | 4 | 05-29-2009 06:15 AM |
