Old 06-25-2011, 03:28 AM
Yazmo is on a distinguished road
Angry Fanuc 10TF Eprom Damaged
Hi everyone,
Currently, I am fixing a Mondiale M-600 Turning CNC machine. The main problem i have encountered is that one of the EEPROM ICs is missing or more precisely damaged cause it was inserted in the wrong orientation when it was served a couple of years ago.
I have tried to start the controller while pressing "7"&"9" keys and completed the procedure. The IPL mode appeared again declaring that there is a problem described by the alarm:
"Servo rom test: error"
I cann't find a turn around solution for this problem since i do not find it in the maintenance manual, but i suspect it to has something to do with this EEPROM IC.
Kindly, can anyone help me by providing the full bunch of the EEPROM ICs found in this controller which i "Believe" they were programmed by the Machine manufacturer and not by FANUC?
Main Board: A16B-1010-0320/05A
IC location: 402
Thanks in advance.
Yazamo
Old 06-25-2011, 08:37 AM
memoryman is on a distinguished road
1: please provide the country where you are located (time zone,language)
2: the servo eprom is programmed by Fanuc and it has the version printed on it, as are the software ones. Only the ladder eproms are provided by the MTB.
3: I will see if we have this specific eprom on Monday and let you know.
Old 06-25-2011, 03:42 PM
Dear MemoryMan,
Thanks a lot for your reply. I am currently in Jordan. From your reply, it seems that we are talking about a Servo Eeprom IC; and that makes me wrong in the sense that this IC is Fanuc Programmed rather than being a MTB as you have made clear to me.
Regarding the Software version, Please consider the following:
IC Type: MBM27256-25
Numbers written on the Label of this IC are:
0100
0106
Should i expect solving the problem by having this IC?
Waiting for your kind reply.
All the Best,
Yazmo
Old 07-11-2011, 08:40 AM
Hope you are fine
Dear MemoryMan,
I hope this post find you well. I am just wondering if you are OK?
Kindly, this is a soft reminder about the subject in hand. Any Progress?
Thanks,
Yazmo
Old 07-11-2011, 06:19 PM
I will look tomorrow for more information on this. Servo eproms are usually supplied by Fanuc; we may have them.
"I have tried to start the controller while pressing "7"&"9" keys and completed the procedure" you lost all parameters by doing this (was not necessary). you have all the parameters backed up? cnc and pc?
Old 07-12-2011, 04:03 AM
Dear MemoryMan,
Thanks again. Yes, I have them Backed up.
I am waiting for your reply.
Best Regards,
Yazmo
Old 07-12-2011, 08:42 AM
Our control is a different model, so we don't have these eproms and we can't help you. Contact tpeloski@naindustrial.com; they can help you.
Good luck.
Old 07-12-2011, 11:53 AM
Dear MemoryMan,
Thank you for your help. I will follow up with them. Hope this will do.
Take care,
Yazmo
Newbie- FANUC 16/18 Series PMC EPROM data ker2008 Fanuc 0 06-24-2011 03:42 PM
FANUC 0 SERIES PMC EPROM CONVERT TOOL ker2008 Fanuc 0 09-05-2010 11:43 PM
Build Thread- Fanuc Eprom MysticMonkey Fanuc 5 11-24-2009 03:26 AM
Need Help!- To burn EPROMs for Fanuc 0T on std EPROM programmer gautam1806 Fanuc 0 10-09-2009 01:14 AM
Fanuc Eprom gabedrummin Fanuc 5 06-06-2009 04:26 AM
