Old 06-24-2011, 07:24 AM
dogwood8488 is on a distinguished road
Cool GE Fanuc Embedded PC
I have never worked with a Fanuc that had the PC embedded in the monitor. Our KOMO CNC router hard drive went out on the onboard pc. My question is can the Fanuc run without the PC? And if so How do you bypass the PC?
Fanuc CNC A16B-3200-0491/02A "OiB"
Old 06-24-2011, 10:43 AM
underthetire is on a distinguished road
That depends on witch embedded one it is. If it used the fanuc software on the PC, with standard fanuc screens, I haven't found a way to do it. There wasn't much to re-load in the PC if it is. All you needed was the operating system (2K, Xp) and load the fanuc software. It should find the node for the HSSB, it will show up as a little motor icon in the right lower tray. Once it finds that it should be able to load the screen viewer. All the program data is stored on the control, as well as parameters.
Old 06-24-2011, 12:18 PM
It is a KOMO CNC Router and we are getting a new cloned hard drive from OEM. Talking to a local tech. he says this particular set up requires the windows operating system for Faunc to run, no way around it.
PIC Embedded design Question musicmkr PIC Programing / Design 24 07-23-2010 10:29 PM
Need Help!- Windows embedded NL DIFF OVER Mori lathes 8 10-21-2009 08:46 AM
Embedded Youtube links have wrong URL (with example) gasmasher CNCzone Club House 0 03-28-2009 10:04 PM
EAS - Embedded Aquisition Systems Graham H General Topics 7 04-16-2007 02:12 PM
Fanuc ethernet embedded 21i-MB RoberChile Fanuc 8 12-31-2006 12:09 PM
