Old 06-23-2011, 12:19 PM
Antonio Arguijo is on a distinguished road
Servomotor FANUC
HELLO EVERYONE,
SOMEONE KNOWS THE DIFFERENCE BETWEEN A SERVOMOTOR
A06B-0148-B176#7000
AND
A06B-0148-B176 ???
OR WHAT'S MEANS #7000 ???
Old 06-23-2011, 01:36 PM
Al_The_Man's Avatar
The motors and encoders should essentially be identical, you have the main number, I don't have the full details but it looks like an motor with brake and serial encoder?
Old 06-23-2011, 02:15 PM
cnc2149 is on a distinguished road
In general, the suffix indicates various 'options' for the motor (e.g. special shaft keyway, bearings, FANUC/GE Fanuc marking, IP67, etc).
For AC SERVO motors, the suffix has the following meaning:
#7xxx (GE Fanuc nameplate)
#0xxx (FANUC nameplate)
For AC SPINDLE motors, the suffix has the following meaning:
#3xxx (GE Fanuc nameplate)
For both types of motors, in cases where the suffix is #0000, they omit the suffix entirely from the nameplate. Therefore no suffix is equivalent to #0000.
Old 07-01-2011, 12:39 AM
A860 ENCODERS
DO YOU KNOW WHAT'S DIFFERENCE BETWEEN ENCODERS ?
A860-2000-T301
A860-2000-T321
I'DON'T FIND ANY DOC'S ABOUT THEM!!!
Old 07-01-2011, 07:12 AM
T301 is the standard encoder
T321 has an O-ring in the flange groove and is used with IP67 motors.
Electrically they are equivalent.
Old 07-20-2011, 11:27 PM
Thanks a lot for your help,
now I have a doubt between differences on the encoder
A860-2020-T301
A860-2000-T301
Old 07-25-2011, 08:12 AM
They have different resolutions and are used in different series of motors:
A860-2020-T301: Beta 128iA (Absolute) used in Beta i servo motores
A860-2000-T301: Alpha 1000iA (Absolute) used in alpha i servo motors
Servomotor Alex S.A Servo Motors and Drives 10 06-10-2008 06:50 AM
Servomotor control IanH Controller & Computer Solutions 2 06-10-2008 01:01 AM
SEM SERVOMOTOR Wanted joesimmers Servo Motors and Drives 0 02-19-2007 07:52 AM
Fanuc servomotor question stude8 Fanuc 2 12-21-2006 08:55 PM
servomotor problem Alex S.A Servo Motors and Drives 16 12-24-2004 01:08 PM
