Old 06-23-2011, 01:37 AM
hell_pk is on a distinguished road
Fanuc 6T G01 command problem
Hi!
A vertical machine with Fanuc 6T controller stopped executing G01 command. Does not give any alarm or error.
Plz advice....
Old 06-23-2011, 05:08 AM
sinha_nsit is on a distinguished road
You are possibly using feed per revolution mode with spindle at rest. Do you see continuous green light on CYCLE START lamp?
Does G00 work?
Old 06-23-2011, 05:51 AM
Other commands are running. Cycle start lamp is green.
Old 06-24-2011, 12:04 AM
G00 is also working
Old 06-24-2011, 03:07 AM
Try G01 with G98 and an F-word (feed per minute): G98 G01 F_;
Problem- Fanuc 0M command to clear the spindle?? Otterpaw Fanuc 3 04-01-2011 12:10 AM
problem with ,C command cncozz G-Code Programing 12 07-02-2008 11:23 AM
Problem with the G70 command markus314 G-Code Programing 25 06-23-2008 01:25 PM
fanuc OT controller skipe M00 command suresh patil Fanuc 2 08-02-2007 08:15 PM
fanuc servo motor moving without command mtech General Metal Working Machines 5 06-16-2003 08:39 PM
