Old 06-17-2011, 02:44 PM
Trapper14 is on a distinguished road
Fanuc series 18-T MDI woes
It's been a while since I've have used a CNC lathe so bare with me. I am attempting to get a FEMCO HL-25 up and running. I know the spindle, turret, and axis are working and homing correctly but I am having trouble with MDI mode.
I switch the control to MDI put in some mode such as M03 S500 EOB INSERT when I bit cycle start, nothing happens.
I have tried putting EOB after each command but I still get the same result, am I missing something obvious?
Old 06-17-2011, 03:25 PM
ad64075 is on a distinguished road
Yes, you are.
Specify constant rpm or constant surface footage.
G97 S500 M3
Try that.
Old 06-17-2011, 03:51 PM
Hmm well I can't try it right now; however what if I try
M06 T02 EOB INSERT
shouldn't it rotate to that tool? Same thing, it just sits there and does nothing.
Old 06-17-2011, 04:04 PM
No, sir. Use a 6 digit tool call. For example, to use tool #2, your code would read:
T0202
Old 06-17-2011, 04:13 PM
ah ha! I am so used to VMCs. I am certain this will work! Thank you all very much, will give this a go Monday!
Fanuc Series O-TC bluepgt CNC-Zone 2 12-31-2010 03:13 PM
Bridgeport Series 2 interact 2 controller woes Teyber12 Bridgeport and Hardinge Mills 6 10-31-2010 05:19 AM
Bridgeport Series II VMC - X and Z axis woes inthezone Bridgeport and Hardinge Mills 1 08-08-2007 09:59 AM
Fanuc Series 18T jorgehrr G-Code Programing 22 02-23-2007 04:21 PM
Fanuc on a Series 2 HillBilly Bridgeport and Hardinge Mills 6 01-07-2006 12:50 PM
