I have a four-axis Bridgeport horizontal milling with FANUC 6MB Control, I can not move the Y axis, review the diagnosis # 97 bit 4 (* ITY) = 0, Check electrical circuit and are pins that are not being used as the other axes, then do not understand why this to 0 and what is the procedure to put in 1. once when I turn on the machine, the diagnostic # 97 bit 4 occurs in 1 but becomes 0 after a time Any help or suggestions will be helpful Regards Nazario |
| That is the interlock bit for the Y-axis. 1: the connection board has a bad input 2: there is a wiring problem up to connector C03 pin 35 on the connection board 3: an external signal connected to connector C03 pin 35 on the connection board is incorrect (see the electrical diagram) |
| diagnostic # 33 bit 4 = 0 diagnostic # 97 bit 4 = 0 when you place a jumper between pin 33 and pin 35 of C03 diagnostic # 33 bit 4 = 1 diagnostic # 97 bit 4 = 0 this means that the diagnostic # 97 bit 4 is controlled by the PC? if so, what can be the source of this problem? |
| Need Help!- how to index or move c-axis on takisawa TX-20 with Fanuc 21-T control | WonderY | Fanuc | 1 | 03-18-2011 04:25 AM |
| Looking for manual for a Fanuc 11 Control | TweedFab | Fanuc | 2 | 02-23-2010 07:32 PM |
| Help! Mach 3 Won't Move my Stepper Motor - Emergency Stop Mode | AntonCNC | Machines running Mach Software | 7 | 02-21-2010 11:23 PM |
| Need Help!- FANUC O-MD Control MAnual | m_bhui | Mastercam | 4 | 11-03-2008 10:58 PM |
| Rapid move axis control | mattpatt | SolidCam | 3 | 08-15-2008 09:51 AM |
