Old 06-14-2011, 12:08 AM
Asfar is on a distinguished road
when i switch on, only apear "Not ready"
this is fanuc control OTTC Mori seiki ZL 45 cnc lathe machine. first we found an alarm ex451, during the time, lubrication pump and cooler unit no work. but if we check, there is no any failier, cooler also working properly if bypass line. Now switch on the machine just we could not go inside only showing boothing scree with message is "not ready"
i checked relays (good) but no on running mode because i feel no passing message from the board. i feel that's why no running cooler and lubrication pump. I dont know much about, please anybody can help me to solve this problem.
thanks.
Old 06-14-2011, 01:03 AM
yuvraj_jhala is on a distinguished road
if not ready is comming at booting screen means your systme hard ware is failed for FANUC 0TTC controll.
You can find 4 system PCB inside ur electrical cabinet. removed i/o board and power on machine. if same status is comming then your system hard ware might me having problem.
Old 06-14-2011, 01:52 AM
thanks brother for your response. actually just i disconnect the line between servo spindle unit and memory board connector. then booting okay and alarm number show 408 spindle drive unit alarm.
DM4400 NO "READY" ON CONTROLLER maddog1927 Dyna Mechtronics 0 12-16-2010 10:58 AM
Newbie- Takisawa TS 10 "Not Ready" Status! julioykaly CNC Machining Centers 5 09-30-2010 05:09 PM
How to monitor VSD-A "Ready" status? LBodnar Granite Devices 19 06-05-2009 07:59 AM
Fanuc 6m stays in "not ready" mode hopcycle Fanuc 2 01-30-2009 07:58 AM
Anyone wish they had a switch for coolant options on the CNC88 "Auto-Off-On" LarryNH Fadal 0 08-04-2007 06:11 PM
