Old 06-11-2011, 11:31 AM
thivanka is on a distinguished road
Question NC lathe stops intermittently at same line in the programme
There is a ECOCA SJ - 35 HT CNC (control is Fanuc Oi - TD) lathe machine. It is used to machine impellers, suction flanges of pumps etc.while it is machining a particular impeller, machine stops intermittently but it occurs always at same line in the programme ( but this problem is not occuring each and every time that programme runs). once it is stopped, the word ' alarm' is shown on one place of the display and also 'hold' word appears (important - running programme is still being displayed on one side of dispaly).
*** again programme start to works and machining happens from where it stopped when we switch on the start button on the control panel.
I want to know whether this problem is due to a problem in programming or due to any other reasons. please help me quickly
HERE IS THE PROGRAMME ( THE LINE AT WHICH PROGRAMME STOPS IS IN BOLD),
O0029(NSP IMPELLER MACHINING INITIAL PROGRAMME)
N1T1010
G50S400M03
G96S45
G0X190.Z150.
X147.9Z3.1
G1X142.5Z3.6F0.11
G2X54.Z13.3R500.F0.2
G0X55.Z26.6
X50.5
G1X0.F0.25
G0X55.Z26.7
Z24.7
X52.
G1X-1.1F0.2
G0Z24.8X45.5
G1Z15.1F0.2
G0X46.Z24.8
X41.5
G1Z24.1X43.35F0.16
Z15.1F0.25
X47.F0.32
X54.2F0.5
G0Z13.5
G1Z13.3F0.16
X43.35F0.23
Z15.7F0.4
G0X250.Z160.
T0M05
M01
N2T0404
G97S280M03
G0X295.Z40.
X0.2
Z-31.2
G1Z-32.3F0.04
Z-34.F0.07
Z-50.1F0.19
G0Z50.
X3.
T0M05
M01
N3T0808
G97S250M03
G0X39.7Z102.
Z40.
G1Z36.6F0.1
G0X38.Z39.
X43.
G1Z36.4F0.1
G0X40.Z50.
X44.Z99.
T0M05
M01
N4T0202
G97S250M03
G0X36.1Z117.
Z24.8
G1X35.27Z24.1F0.1
Z21.4F0.2
Z20.85F0.1
X16.4F0.16
G0Z25.
X45.Z110.
T0M05
M01
N5T1212 // Tool changer changed to under cut tool from boring tool
G97S200M03
G0X29.Z137.
X17.
Z5.5
Z1.75
G1Z1.2F0.14
X14.4Z-0.2F0.1
Z-10.95F0.115
X16.4F0.07
G1X13.7F0.4
G0Z140.
X18.
T0M05
M01
N6T0606
G97S230M03
X35.Z99.
X32.
Z-40.
G92X35.65Z-52.5F1.41
X35.85
X36.05
X36.15
X36.3
X36.5
X36.53
G0Z-37.X34.
Z99.
X230.
M01
M30
Edit/Delete Message
Old 06-12-2011, 01:35 PM
John_B is on a distinguished road
The bold highlighting doesn't show for me, can you add quotes or something (maybe >> xyz f <<).
Old 06-13-2011, 06:58 AM
sinha_nsit is on a distinguished road
Might be due to optional stop M01.
Check the status of optional-stop switch on the MOP.
Old 06-13-2011, 09:34 AM
@jhon B
here is the programme line where machine stops.
Old 06-13-2011, 09:35 AM
what do you mean by MOP?
Old 06-13-2011, 11:02 AM
newc is on a distinguished road
Machine Operator's Panel
Old 06-13-2011, 11:39 AM
mfgbydesign is on a distinguished road
Get rid of the comment or use parens instead of slashes. might be confused with block skip by the control. Use ALL CAPS for anything in the program, including comments.
The T0's prior to the tool change may be cancelling offsets & causing the machine to think it's going overtravel. I've never seen a need for a T0 in a lathe program.
I am also not understanding why you stop the spindle (M5) prior to tool change. The machine might not move X or Z without the spindle running, and it probably wants to make a move with the new tool offset.
Old 06-13-2011, 12:37 PM
MKMANU is on a distinguished road
use parenteses get rid of the slashes../ is block skip // is probably causing the alarm
Old 06-15-2011, 01:08 AM
this slashes and the comment doesn't exist in the real programme. that is something i added later inorder to give viewers a idea what is happening at the programme when problems comes. so those slashes and the comment cannot be the cause of the problem.
Old 06-15-2011, 04:23 AM
viorel26's Avatar
viorel26 is on a distinguished road
Go to message screan and see what alarm appears
  #11   Ban this user!
Old 06-15-2011, 06:10 PM
I think you may want to try a G0 in front of your toolchange line. I have a lathe that requires this, don't know why - but it does... Other than that I have no other ideas...
  #12   Ban this user!
Old 06-15-2011, 09:08 PM
Dan Fritz is on a distinguished road
What kind of tool changer does this machine have? Does the tool change to T12, then the machine stops, or does the tool change not happen?
Something may just be putting the control into "Feed Hold" momentarilly. The Feed Hold switch is normally closed, so any loose connection in that +24v circuit will put the control into Feed Hold. You can resume from any Feed Hold condition by pressing Cycle Start again, but we need to find out why the Feed Hold is happening. Could it be a switch in the tool changer?
Intermittently Supported Linear Ball Bushing Rails Chuck_M Linear and Rotary Motion 1 12-12-2009 10:57 PM
Need Help!- It stops after every line of code Farmers Machine CamSoft Products 3 11-15-2009 02:41 PM
Fadal 4020 stops at line 13 or 16 in program ThatguyDave Fadal 10 09-09-2009 02:57 PM
Spindle brake fuse blows intermittently AndyB Fadal 1 08-20-2007 10:14 AM
I put Carriage stops / E-stops on the x&y Shoptask 1739 Gunmaster....I was bored lol spunky1974 Shopmaster/Shoptask 0 06-30-2007 04:13 PM
