Old 06-07-2011, 03:58 AM
Swemill is on a distinguished road
Fanuc 10M - 2nd limit switch problem!
Did a big mistake and turned out of working area - into a limit switch (in Y axis) before i did a zero return...
I managed to get out of the limit area with 2'nd release switch but now i cant get rid of the alarms and the machine seems to be in emergency stop mode.
Tried with p + can under power up but that seems not to work on Fanuc 10M!?
Anyone that know how to fix this? I believe that the limit switchs is working and is not stuck because it "clicks" when i press it.
The alarms is:
EX06 Emergency Stop.
EX11 2nd Limit Switch is Working.
The mill is a Kitamura Mycenter 1 -85 with Fanuc 10M.
Help Please.... =)
Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
Yes, they are old..... but i still like them!
Old 06-07-2011, 04:31 PM
Fixed this tonight and a bit embarassed i could state that it was a stuck 2nd limit switch...
I cant understand how this has happened because it was in X-axis and not Y (that i moved) but in some way that switch has been pressed!
Tried first to "disconnect" check soft OT at power on - in IPL mode, but that didn't made any difference. Found the stuck switch, fixed it and pressed "Y" to - check soft OT at power on - in IPL mode but then i couldn't zero return.
Pressed "N" again at the mode above and then it worked!
/Thanks.
Old 12-27-2011, 05:20 PM
chaparro is on a distinguished road
good afternoon I need the parameters for Mazak CNC lathe
Quick Turn 10N model
fanuc control type F-10t
someone who can help will be appreciated my phones are
011 52 614 4 25 26 36 or 01152 614 4 37 25 44
my e mail is oscar_chaparro@integralchihuahua.net
Old 12-28-2011, 12:39 AM
gbowne1 is on a distinguished road
Well swemill my problem which is similar on my 16M is intermittent. Sometimes it does this sometimes it doesn't, and no it's not stuck. I just wonder if I got the I/O wiring right. But if you can, put up some pics of where yours is wired to.
Old 12-30-2011, 11:23 AM
tmbruno28 is on a distinguished road
i can send you parameter and pc parameter for the same machine
Old 01-06-2012, 01:51 PM
much will it cost to send me information
Limit switch problem paulb DIY-CNC Router Table Machines 5 07-13-2009 05:49 PM
Limit switch problem? Bill Gillen AjaxCNC Control Products 2 05-08-2008 12:02 PM
Limit Switch Problem tz1238 Machines running Mach Software 4 02-07-2008 04:00 PM
Limit switch problem jimini Mach Software (ArtSoft software) 5 09-17-2007 08:49 PM
Problem With IH Limit Switch. Willyb Industrial Hobbies (Support forum) 5 11-06-2005 05:17 PM
