Dear all On my OT machine, I have the trouble as: In MDI mode, when I keyin the command already, I pushed Cycle Start button, but nothing happen, and the command is not disapear on screen, as the machine is not recieved the command( I check all DGN witch is concept, but find nothing). Pls. help me the way to fix this problem. Thanks |
| Dear dcoupar Thanks for your reply. I typed command like as: (for example) T0606-> EOB-> insert-> Cycle Start, the command does not disapear on screen and the machine doing nothing. The Cycle Start light is do not light up. |
| Dear sinha_nsit Yes, the machine is in ready-to-execute condition, the hydrolic is On, all interlock is released,....( because I checked all DGN 700, 701 and 712, all they is 0). The machine can run in Home return mode, JOG mode, and even in Auto and MDI mode normanly. And suddenly, the MDI mode and Auto mode is not run( in this time, the machine still run in JOG or Home Return mode as normaly). I can not understance why? Thanks a lot for your time. |
#10
| If you have macro programming on your machine, execute #1 = 1 ; (EOB has to be there) and observe if the CYCLE START button lights up for a fraction of a second. It appears that AUTO and MDI modes are not working at all on your machine. I am not sure if it is a parameter issue. Did somebody play with the parameters? Was the machine working properly in the past? When and how did the problem appear? |
#11
| Dear sinha_nsit Thanks you so much for your reply. The machine work fine before the problem was on, I'm is one work with the machine same as usualy and do not play with parameter, but suddenly the machine can not respone Cycle Start button( but I can show in Dinostic screen, even in Ladder screen, the Cycle Start button was still received by controller). |
| Need Help!- Trouble with V24 | robrea | BobCad-Cam | 17 | 05-14-2011 04:49 PM |
| Trouble with homemade CNC machine glitching | ink251 | DIY-CNC Router Table Machines | 5 | 07-30-2010 12:01 AM |
| Newbie- PLC trouble | dipakkadam_619 | Stepper Motors and Drives | 1 | 11-30-2009 02:17 PM |
| Am i asking for trouble? | phantomcow2 | DIY-CNC Router Table Machines | 16 | 01-02-2006 06:35 PM |
