Old 05-27-2011, 12:39 PM
supreme_hinge is on a distinguished road
Amada Pega Turret punch E Stop Reset
Our 1985 Amada Pega 20-40-40 turret punch won’t start because of an ‘error 14 emergency/reset” . We checked the 2 E stop switches and they are both reset. We checked the fuses to the best of our knowledge and tried to reset all the circut protectors. The ‘Clamp open’ , ‘Tool change Switch’ & ‘X Block’ lights are on. The fans come on but the motor isn’t turning.
It has a Fanuc-P System 6M controller.
HELP!!!
Old 05-30-2011, 03:26 PM
perfpro is on a distinguished road
Could be the flywheel hasn't stopped at Top Dead Center, if you have hit E-stop button during operation. You should have procedure for getting to Top Dead Center, in the operator's manual look for 'Preparing for Operation' or something like that.
Procedure is at initial power on, if TDC is not lit, select manual mode, set index pins IN, close workclamps, set press selection switch to 'Inching', then press and release 'Punching' button until TDC is lit.
Old 05-30-2011, 03:55 PM
14 error
Thanks for the reply but we couldn't even get the unit up to reset the top dead center error if we had that. We have that problem time to time but know how to correct it. It turns out that we had a blown fuse that we replaced and we are back up. Believe it or not, Amada told us we had a blown fuse and to check them. We did and its all good now. Thanks for ther help anyway and I am sure I will need more. I will also help when I find a solutition to a problem for all the others out there. Thia is a great website....let keep it going boys!
Need Help!- Amada Pega 344Q DHO.nl Controller & Computer Solutions 3 03-21-2012 10:22 AM
Pega 344 Amada Fanuc 6M electrical diagram nguyenthanhthi Fanuc 8 10-21-2011 08:31 AM
Need Help!- Amada Pega 244 w/ Fanuc 6m B controller memory replacement MetalForce Fanuc 10 08-10-2011 04:14 PM
Amada Pega 345 X axis parallelism problem terrycoughlan CNCzone Site News and Contests 2 06-08-2011 04:22 PM
Need Help!- Amada pega fanuc 04pc system error cndcnd Fanuc 7 04-01-2011 01:19 PM
