I'm new here so please bear with me. I need help setting the safety area on a doosan mill with a fanuc 31i control. I'm thinking it's paramter 1321 but not sure on how to get it right. I need to move the spindle closer to the table in y axis when the z (column is closer to the table) thanx in advance, mike Last edited by mbromaghim; 05-26-2011 at 09:15 PM. Reason: added need help to title |
| What model machine is it? What values do you have in parameters 1320-1323? 1320 & 1321 are the standard overtravel parameters. I think the values in 1322 are the ones you need to adjust. 1323 should be ok the way they are. I checked parameter #1322 for an HP4000. Y was 100.0 and Z was 165.0. These values coincide with the values on the interference zone diagram attached (with 50mm extra in Z). So if you need to be able to bring the Y down 0.25 (6.35mm) for example, change 1322 Y from 100. to 93.65. But in any case BE CAREFUL. Crashes in this area can be REAL expensive. |
| it's a DBC 130 horizontal mill. I make changes to the parameters and nothing seems to change like they should. I shut the power down and restart, and the numbers I put in are still there but nothing changes as far as the limits, I'll try again on tuesday, I was told to change the keep relay to turn the zone off but that will be my last resort, thanks |
| well , I tried changing the values in 1322, and absolutely no change in the safety zone, I even tried turning them off on each axis with another parameter and still no response, so I turned off keep relay parameter 8 bit 4 and adjusted the standard over travels to keep it from crashing with the spindle out over the table, not what I want but seems right now the only way I can get this thing to do what I want, to get the thing to machine out over the table down closer to the table. Thanx for the help, hope someone out there has the answer, it seems to be locked out from the factory some how, Mike |
| z axis stroke limit on fanuc wire edm | REVCAM_Bob | Fanuc | 1 | 05-22-2011 11:24 AM |
| Fanuc 15MB - Option Prm to Increase No. of stored Files. | bionic-bean | Fanuc | 1 | 11-04-2010 07:53 AM |
| Fanuc 0M - Changing Axis Limits | MotoDan | Fanuc | 6 | 07-23-2010 07:28 PM |
| Need help with stored limits- Fanuc 6MB | celtic-mfg | Fanuc | 1 | 01-10-2007 09:33 PM |
| Fanuc OM soft limits reset? | CNC Biker | Fanuc | 4 | 04-25-2006 09:33 PM |
