Hi All, I have searched for hours now and I cannot find anything to help me with what seems to be a simple matter. I accidentaly deleted the parameters for my Fanuc 3M Model A controller. Luckily, they were printed so I easily reinput them. The settings page (just before machine parameters) was also reset to all zeros. To use inches on the machine the parameter setting needs to be input as a "1". However, the machine will not accept it. All the other setting parameters will change from "0" to "1" but not this one. I also tried to input G20 in MDI mode and I received Alarm 010 which says it is an invalid G Code. The machine has always been used in inches mode and the dsiplay always showed inches. However, in the past I did once switch to metric to see if it worked and it did. It also switched back to inches at that time. I can't understand why the controller is not allowing the change now. Any ideas? Thank you! David |
| Thanks memoryman! I thought it would be something simple. Funny, my printed list of parameters began at 004 and my maintenance manual also started at 004. So, I did not input parameters 001 through 003. Can you tell me what the other bits of these three parameters are for or where I can find a list? Thanks again! David |
| here they are. FANUC SYSTEM 3 KNOWN OPTIONS 1.0 CANNED CYCLES 1.2 RADIUS PROGRAMMING 1.3 HANDLE FEED 1.4 CONSTANT SURFACE SPEED CONTROL 1.5 INCH/METRIC CONVERSION G20/21 1.6 SPECIAL G CODE INPUT 1.7 PC ENABLE 2.2 EXTRA MEMORY BOARD 2.3 20m PPS 2.4 CHAMFERING AND CORNER ROUNDING 2.5 I/O INTERFACE EMABLE 2.7 M.R.C. 997.0 MENU PROGRAMMING 997.5 TOOL GEOMETRY + TOOLWEAR OFFSETS 997.6 TOOL NOSE RADIUS COMPENSATION |
| Need Help!- Ultimax Dual Screen Keyboard not working | islandracing | HURCO | 2 | 01-25-2011 02:11 PM |
| Need Help!- G203V- Steps/Unit Settings in Mach3 | Khalid | Gecko Drives | 0 | 08-25-2010 03:34 AM |
| Auto Heigh Control unit Not working properly | PHSS | Torchmate | 6 | 06-10-2010 11:04 AM |
| Set-up / Steps per Unit / Threads per Inch | adda | Mastercam | 2 | 01-15-2007 04:29 PM |
| New 5 axis screen set I've been working on | Darc | Screen Layouts, Post Processors & Misc | 14 | 04-10-2006 02:38 PM |
