Old 05-16-2011, 12:41 PM
crasher455 is on a distinguished road
FANUC OM MATE RETROFIT HELP NEEDED!
Here is the background on this project. I removed a Fanuc OM control from an Accel Kiwa 810 VMC that was scraped and want to install it on a Devlieg horizontal borring mill that we purchased.
When I removed the control from the Accel I left the control cabinet completely intact and the parameter battery is still hooked up.
For now I only want to use it as a 2 axis control for point to point drilling and contour cutting.
Is there a way to disable the other options in the control for the z axis, spindle, and tool changer so the machine will operate correctly?
I'm also looking for a good source of pre made fanuc encoder cables approx 15ft long.
Any help would be greatly appreciated.
sick minds demand sick toys!
Old 05-16-2011, 06:43 PM
tc429's Avatar
tc429 is on a distinguished road
I think your biggest problem will be with the ladder- that cabinets wired for a certain machine with certain functions...simple things like cycle start or hold will require fooling inputs that the t/c is retracted, stuff like that, plus what if their logic requires homing all 3 axes before cycle start...you can dummy out the third axis with 2 simple plugs, but you'll likely need to get into the logic to be able to run it.
your best bet will be to get a copy of the old IBM fladder, edit your existing ladder in ram to suit your needs...if youve got anyone that does any brand of plc work, they should be able to sort it out easily- Fanucs PMCs are one of the simplest to work with out there...you would need a pcwriter eprom burner too to read in the old ladder, and burn your final copy once finished...come to think of it- theres a ladder editor card you can plug in to a -C control (should work on a mate) Ive never used it, but think it might work too...but editing ladder without text sucks- maybe the editor adds text, but I doubt it. I dont know if the editor has eprom sockets, or if it requires pcwriter to upload eproms.
if you can find a local retrofitter, he could probably get you 90% ready to start wiring in a hour or two, maybe another couple hours fine tuning functions... theres a company in Canada that makes great cables very reasonable (we get their robot pendant cables- they take a lot of abuse and we never seem to have time to make them up) one thing about fanuc cables though- you might need to go huge on sealtite, or split flange your cable inlets if you buy premade...think you need a 1" knockout or bigger to fit a honda plug thru- even with the shell removed...the cables are not difficult to make at all, you can usually find the honda and amphenol plugs on ebay for cheap- if you do make your own just be certain to triplecheck you put all the amphenol shell pieces on before you start soldering- Ive pissed myself off soooo many times getting distracted and forgetting a clamp or something
*If you buy honda plugs, get the solder type- crimpers for the crimp type plugs are very hard to come by...I actually found a pair on ebay for 15 bucks-made my day, as honda charges like 700 bucks for a pair!!! they work great, make perfect plugs, but are about rare as hens teeth to find reasonably priced...other crimpers like the little radio shack rs232 pin crimpers *can* work in a pinch, but you'll need to solder them after crimping to be sure they hold...good luck
Tim
Old 05-16-2011, 07:25 PM
I did some more searching today and found 2 different companies that can make the encoder extension cables I need for this, at a very reasonably price $125.00 per cable. I know I can buy the Amphenol connectors and cable for less money but I don't have the patience to solder on 68 pins.
Tags
fanuc om retrofit
Fanuc O-MD or Oi-mate? Genguy General CNC (Mill and Lathe) Control Software (NC) 3 08-19-2011 04:15 AM
Fanuc O-Mate M dnc diemaker General CNC (Mill and Lathe) Control Software (NC) 1 05-09-2011 02:52 PM
fanuc 0 mate M dasandy General Metal Working Machines 2 07-21-2010 08:47 AM
G76 in Fanuc Oi Mate m_ghaff2000 Fanuc 1 07-14-2008 01:53 AM
fanuc mate M dasandy Fanuc 6 06-12-2008 05:00 AM
