Old 05-12-2011, 02:28 PM
motordude is on a distinguished road
Fanuc 0i-mc tool crash
Hello all,
I was setting the tool length and before doing so I wrote this line (as usual): G30G91Z0.
Normally the machine returns to zero, but not this time, it went in opposite direction into the table.
How is this possible? What did I do wrong?
Best regards
John
Old 05-12-2011, 07:52 PM
underthetire is on a distinguished road
Seen it before, but with a G28 (first zero return). Every time the G91 was omitted. I know there are a few on here that says you don't need the G91, but all the Fanucs i've set up need it. We had an apps guy do that once, brand new machine, never even cut a part. Bounced the Horizontal spindle off the pallet. 50K damage to the machine. Full rapid 2400 IPM.
Old 05-14-2011, 05:54 AM
jvangelder is on a distinguished road
If im doing a refrence return though code ive always used G0G49Z0.
However on an OI-MC you shouldnt have to clear the current height offset to set a new TLO, just jogg the tool to place, then on your desired tool offset punch Z, then hit the input C soft key
After crash zero return doesn't go to tool 1. AvtekMfg Haas Mills 0 08-16-2010 11:52 PM
Newbie- Tool crash after reconfig deanbayley Mach Software (ArtSoft software) 3 08-29-2009 05:13 AM
Tool Crash During Simulation Problem Cartierusm Dolphin CADCAM 8 05-29-2009 02:09 PM
Need Help!- TOOL CHANGE PROBLEM AFTER CRASH roadking Fanuc 21 03-23-2009 08:55 PM
Tool changer crash Vern Smith Haas Mills 51 05-05-2008 05:36 PM
