Old 04-29-2011, 12:26 PM
1234567 is on a distinguished road
faunc 15-m alarms
I have a toyoda hmc that has been giving me several alarms...they happen about 6 times a shift.."ex17 servo ready off on spindle rev"....after you reset this alarm "svoo3 y abnormal current in servo"Some times the abnormal current is in x y and z or z and xor just z.This always happens right after the tool change .Before it even gets into the cut.Is this a drive issue or servo motor issue or somthing else?
Any help would be great
thanks, Dave
Old 04-29-2011, 01:43 PM
underthetire is on a distinguished road
Shooting from the hip here, check your spindle orientation. If the ATC arm is trying to move the spindle in M19 mode, it may be causing an overload.
Old 04-29-2011, 02:07 PM
servo
Way lube alarm was jummperd out ...Ways were dry ..it appears none of the operators were filling the way oil tank...I bet thats the problem...Hopefuly the ways are not damaged.
Need Help!- alarms kling8 Fadal 2 10-27-2009 10:22 AM
Need Help!- Alarms sjj Mazak, Mitsubishi, Mazatrol 1 09-02-2009 08:16 AM
ALARMS ALARMS ALARMS tunitime Okuma 5 08-05-2009 11:37 AM
Faunc series 15T error MrMark Fanuc 2 08-18-2007 01:12 PM
Postprocessor for Faunc Oi Mate-MB on Sharp 2412 Mickey_D SprutCAM 2 07-21-2007 05:51 AM
