Old 04-27-2011, 01:55 PM
Mark and Poco is on a distinguished road
General Numeric 6t parr, back up
We are about to move one of our machines, and want to back up the paraters. Does anyone know how to back them up on an old General Numeric FANUC controller??
Any ideas at all please reply asap. move is tommorrow morning.
TRhanks in advance to everyone.
Old 04-27-2011, 02:44 PM
hrh hrh is offline
hrh is on a distinguished road
Parameters:
PARAMETER SCREEN; Type P-9999; Press PUNCH (Machine must be in EDIT mode)
Programs:
PROGRAM SCREEN; Type O-9999; Press PUNCH (EDIT mode)
PC (Programmable Controller) Parameters:
This is as long as the machine is NOT a Mazak or Wasino or anything with an external programmable controller.
Cannot be punched to computer.
Press PARAM twice or press PARAM once and PAGE UP.
Type N1001 and press INPUT. Write down from N1001 until the point where the data goes blank. These are PC timer parameters.
Type N2001 and press input. Write down. These are PC counter parameters.
Also see N2101. Sometimes this is the current tool number for the turret.
Type N3001. Write down same as the 1000 series but will be data in byte format example: 00011010
You should be able to punch out the OFFSETS by typing P-9998 and press PUNCH. The offsets will be punched out as a program which can be READ in and executed as long as you have the G10 option enabled.
Need Help!- General Numeric GN6 Series Mark and Poco Fanuc 2 11-22-2010 02:15 PM
Need Help!- General Numeric Redryder_85 General CNC (Mill and Lathe) Control Software (NC) 8 10-16-2009 12:16 AM
Need Help!- GN6 Series General Numeric Controller cncnavy General CNC (Mill and Lathe) Control Software (NC) 0 01-22-2009 01:10 PM
RS 232 - General Numeric question..... dukejavelin General Metal Working Machines 0 06-05-2008 09:51 PM
GN6 (General Numeric) Helical milling pauldkeeton Fanuc 5 02-23-2007 03:42 PM
