got a okuma lathe a while back and just started playing with it,it has a fanuc 18-T control on it, it was in a GM production plant and the single block, feed traverse overide, rapid traverse overide and rpm overide are all locked out, i cannot figure out what parameters i need to fix, anyone have any idea? thanks for your time |
| Rob, I have seen some vertical lathes that came from a GM plant that had a custom screen written in C language that let the engineers control what the operator could and could not do on the machine. If this is the case you will need the password for the higher level that shows the settings in the custom screen. Good luck, short round |
| These functions are normally controlled from the ladder logic using G-addresses. Look at the following coils: G46.1 when this is high the machine enters single block G10 through G11 These form a binary pattern to control feed rate override G14 bits 1 and 0 Rapid override G30 a binary pattern that establishes the spindle override It's easy to modify the ladder to prevent the operator from manipulating the cutting program. |
| Fanuc 18i Parameter question | fanucuser1 | Fanuc | 5 | 06-06-2010 07:34 PM |
| Fanuc 6TB control axis screw compensation parameter question | JohnF | Fanuc | 2 | 12-07-2009 04:25 PM |
| Fanuc 18T program/parameter question | mikeyson | Parametric Programing | 2 | 10-06-2008 12:30 PM |
| Parameter (I think) question. | g-codeguy | Hardinge Lathes | 4 | 05-18-2008 02:06 PM |
| Fanuc O-M Parameter question | caddyshack | Fanuc | 1 | 04-22-2008 08:00 AM |
