Old 04-23-2011, 12:23 PM
CVMW is on a distinguished road
24v fuse blowing
I have a Takisawa machining center fanuc 10m control. the machine was in the middle of a tool change when it alarmed "E-STOP" type alarm, I found that the 5 amp fuse on the 24v power supply (F14) had blown, I replaced it and powered up, blown again!, I must have a short somewhere, but I have no idea where to start looking.
Can someone point me in the right direction?
Thanks in advance,
Willie
Old 04-23-2011, 01:36 PM
Al_The_Man's Avatar
You need to get yourself a 10 Maintenance manual, F14 is the 5amp 24v dc supply for the connection I/O unit, so basically you have a short on one of the external inputs or outputs, you need the machine prints and using a meter on the ohms scale connected across the 24v on the card measure for low resistance, then if the board has multiple I/O plugs and sockets, remove them one at a time and see which has the short when the meter goes to higher resistance, you will then have to test each of the likely circuits in turn for a short.
blowing ifc dps fuse robthomas Bridgeport and Hardinge Mills 0 09-07-2007 07:20 PM
Mechatronics controller blowing fuse! WilkBoy Stepper Motors and Drives 4 06-24-2007 09:43 PM
Fuse Blowing! Please Help audioandy1762 Gecko Drives 6 01-22-2007 03:52 PM
BP series 1 x axis fuse blowing keebler303 Bridgeport and Hardinge Mills 5 07-08-2006 02:23 PM
Fuse blowing at start-up emergent Daewoo/Doosan 4 03-22-2006 12:42 PM
