Old 04-20-2011, 05:17 AM
scteff is on a distinguished road
Fanuc 16 mt manuale
I'm searching for Fanuc 16 MT manual.
It's installed on a MoriSeiki SH-50 and branded as MSC 516.
The shop gave me fanuc i series manual (B63014IT/02) referring to it, but I'm not sure that it's the correct one.
If you could give me some hints (the manual code will be sufficient) !
Thanks !
Old 04-21-2011, 06:38 PM
memoryman is on a distinguished road
can you describe the control?
Old 04-22-2011, 02:56 AM
So.. the control seems to be a traditional fanuc HMI.
I cannot describe it very clearly because i'm not working on that site now.
I found a picture on the internet of that control. is that:
http://www.bidspecialists.com/142475g.jpg.
Inside the cabinet you can see the fanuc controls, "old style", the grey ones with yellow borders.
What I know for sure is that comes with a data server with AUI connector (transceiver installed. separated module from the HMI interface) . And it has the options for High speed machining (20k rpm spindle, if I remember well by operator's words)
The machine came with (as told before) the b-63014/IT (italian, but EN is the same code) operator manual; I'm pretty sure that the operators learned from that manual but, acording to some informations I found in the internet, it seems to be a 16 cnc (not a 16i).
What I really need is to understand the real capabilities of the machine to be compatible with ethernet Focas because focas manual is not pretty clear about that. According to that, 16i - A and B are fully compatible with the functions I need; the 16 isn't.
Thanks.
Bye
Old 04-22-2011, 08:30 AM
It looks like a 16i, but can't be sure ;when you say 16m, there are 3 major versions (a,b,c) and minor variations.
How old is the control?
Old 04-22-2011, 08:35 AM
It's installed on a Mori Seiki SH-50. Searching on the internet I found some of them of around 1996, so I think it could be of similar age.
Old 04-22-2011, 12:50 PM
~1996 would be a 16b or 16c. Here is how to determine the exact model.
Press the SYSTEM key and you'll see the SYSTEM CONFIG SLOT screen.
Look for slot 00 xxXX: 40 . Let me know what XX is.
Old 04-22-2011, 01:08 PM
Thank you. As long as I came to the shop I'll forward you this info !
So, if it's a 16 b/c is not focas compatible via eth?
Old 04-24-2011, 10:03 AM
"So, if it's a 16 b/c is not focas compatible via eth?"
I don't know yet but will know by Tuesday.
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Need A Quote- manuale d'uso fanuc 21i-T luisforni CNCzone Club House 0 10-15-2009 12:16 PM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
