Old 04-19-2011, 08:10 AM
Reyad is on a distinguished road
1001 lub timeover
Hello
I have a yang smv-1000 cnc machine with a fanuc 0M-D controller which stopped working yesterday when i tried to home the z axis
the z axis went to it's home position and the home position led turned on but after that an error message( 1001 LUB time over ) appeared
can any one please tell me what caused it ?
and how to fix it or skip it ?
i have lubricated the machine but nothing happened.
Old 04-19-2011, 01:43 PM
bobancurug's Avatar
bobancurug is on a distinguished road
And if the machine does not drive to the reference point does alarm appears?
Try to power on the machine and not doing anything 5,10,15,20 minutes.
This alarm usually appears if the pressure switch does not receive adequate lubrication pressure in a time frame that is set up machine manufacturer.
Check does the on central lubrication pump raises the pressure on gauge, if exists pressure this mean that the oil pressure switch faulty or oil not generally comes up to him.
Old 04-19-2011, 03:41 PM
avtechmachine is on a distinguished road
Alarm 1001
Press RESET + FEED HOLD to reset alarm and make sure to lube all axis after reset alarm
Ahn Vuong
ahnv@avtechmachine.com
Old 04-20-2011, 02:57 PM
thank you very much it worked will
i think fanuc is a little complex comparing to other pc based cnc's
Need help with yang smv-100 Error no.1001 lub time out murad Fanuc 4 04-20-2011 02:03 AM
Seal/Washer In UNIVER Valve Type AE 1001 Replacement On Bridgeport Help!! Huntersyv Bridgeport and Hardinge Mills 1 02-07-2006 01:02 PM
