Old 04-18-2011, 07:13 AM
murad is on a distinguished road
Need help with yang smv-100 Error no.1001 lub time out
I have a yang smv-1000 cnc machine with a fanuc 0M-D controller which stoped working this morning when i tried to home the z axis
the z axis went to it's home position and the home position led turned on but after that an error message( Error No. 1001 LUB time over) appeared
can any one please tell me what does it mean and what caused it ?
I searched every where on the internet to figura it out but i didn't find any thing because the error messages above 1000 are for the manufacturer (yang cnc) and not for the fanuc 0M-D controller
yours murad
Old 04-18-2011, 12:10 PM
underthetire is on a distinguished road
The machine didn't get proper lube pressure in the specified time.
Causes:
Bad pump
Bad pressure switch/broken wire
Broken line
Stuck metering block
Dirty filter/tank
Old 04-19-2011, 08:47 AM
Thank you underthetire for your reply,
I will check my machine lube today, but is there any key i could press to bypass this error to mack sure every thing is ok because i know that my machine (yang smv1000) lube manually (without pump)
my controller model is fanuc 0-MD
Old 04-19-2011, 05:32 PM
avtechmachine is on a distinguished road
Alarm 1001
Press RESET + FEED HOLD to reset alarm 1001, but make sure to grease all three axis after reset alarm
Ahn Vuong
ahnv@avtechmachine.com
Old 04-20-2011, 02:03 AM
Thumbs up problem solved
Dear avtechmachine,
Thank you very much i tried it and the problem solved
Yang SML-20 error codes Tony in Indiana Fanuc 3 09-12-2010 08:01 AM
Yang SML-20 error codes Tony in Indiana CNCzone Club House 0 09-11-2010 02:10 PM
TC4 error - auxfuncs: spindle time-out emvali Bridgeport and Hardinge Mills 7 03-03-2009 11:45 AM
Seal/Washer In UNIVER Valve Type AE 1001 Replacement On Bridgeport Help!! Huntersyv Bridgeport and Hardinge Mills 1 02-07-2006 01:02 PM
Run Time Error Line Mr.Chips Forum Questions or Problems 2 02-03-2005 09:57 PM
