| Hello! I bought a few days ago CNC lathe ANGELINI model: TORNIO CNC type: OSCAR. system FANUC 18I-TB When I connected the machine, there was 12 alarms: 1002 not out 1006 spindle drive-in alarm 1012 alarm-driven tools 1015 subspidel alarm 443 x axis cooling fan failure 443 z axis cooling fan failure 443 b axis cooling fan failure 610 x axis CNV cooling fan failure 610 z axis CNV cooling fan failure 610 b axis CNV cooling fan failure 9059 SPN1: cooling fan stop in PSM 9059 SPN3: cooling fan stop in PSM on power units are the following alarms: A06B - 6110 - H026 ALARM 02 ON DISPLAY A06B - 6111 - H022 # H550 59 ALARM 59 ON DISPLAY A06B - 6112 - H011 # H550 59 ALARM 59 ON DISPLAY A06B - 6111 - H006 # H550 59 ALARM 59 ON DISPLAY But I should note that all fans are working properly on power units. All cables are in place, the batteries are good. I need help, what could be causing this? Some cable perhaps? I checked all the cables and it seems that everyone in the right place. Machine was working when I bought it. What could happen during transport and cause so much alarm? Thanks in advance for your responses! |
| Dear sir; Your FANUC power supply module is failed. Please repair or replace with new one after that your machine will run hope fully Email id: Subhani_engr1@yahoo.com Skype: Sulemankhosa Messanger yahoo: Subhani_engr1@yahoo.com |
| Thanks for your reply Suleman, but I doubt that the power unit is defective, because before the transport machines worked properly. And please not to get angry but I do not like advices from the maintenance manuals, such as replace this or that for each type of alarm. Because everything can be repaired, I believe that no one is buying parts of a few thousand dollars for each alarm that occurs. In any case, thank you for your reply. |
Dear Sir, How are you? Today I have to discuss my one machine problem in detail. Problem: System alarm 970 NMI occurred in PMC LSI device. Fanuc manual said replace the main board PCB. Machine MAIN mother board with screen is A02B-0283-B500 Parts of this mother board is A20B-3300-0280/04B Graphic card A20B-3300-0311/08f CPU card A20B-3300-0390/02A Servo control card A20B-3900-0164/04A DRAM/SRAM card A20B-8100-0661/10E Mother board PCB I am waiting for your positive reply. Email id: Subhani_engr1@yahoo.com Skype: Sulemankhosa Messanger yahoo: Subhani_engr1@yahoo.com Thanks Dear sir; for your machine i think power supply have problem of any loose conection between main board PCB and control PCB where seven segment mount. 2nd jack of power supply module FAN is loose or may be disconect please check. If u can help me to solve my above system alarm problem then i m very thankfull to u |
| Fanuc 21-tb alarms | Hlynur | Fanuc | 7 | 03-31-2010 12:08 AM |
| Need Help!- Fanuc O-T Alarms | deltaguy | Fanuc | 4 | 02-04-2010 10:33 PM |
| ALARMS 600 AND 607 ON FANUC 6M | POSADAS | Fanuc | 4 | 09-04-2008 01:37 PM |
| Fanuc 0t-C 409, 414, 424 alarms | acerocket | Fanuc | 0 | 11-14-2007 09:47 PM |
| Fanuc 0TC with 409 AL-31 alarms | bob1112 | Fanuc | 12 | 07-06-2007 06:04 PM |
