Old 04-12-2011, 08:20 PM
Stpgagnon is on a distinguished road
Question Need to add a door interlock on a Feeler FTC-20 CNC Lathe...
I'm looking to put a door interlock on this lathe. The controller is a Fanuc Oi-TB.+ The problem is that we don't have this option on this lathe and i don't know where to connect the interlock... Do i have to set some parameter and do the ladder need to be upgraded? Or any other way to secure the door when the lathe is running in auto?
Old 04-13-2011, 01:12 PM
msa msa is offline
msa is on a distinguished road
Hi
It mid bee in the ladder and can be opend with a kiprelay or the ladder nead to brogamet.
if you opload the phe pmc i tjel it for you.
Old 04-13-2011, 05:25 PM
GPena is on a distinguished road
You could do it serial to the feed hold signal...
feed hold safety
switch
This way when you open the door the machine will stop moving.
GP.
Old 04-13-2011, 07:35 PM
GPena;
Good idea! Pretty simple to install... I'm just gonna check if i can still move in jog while the feed hold is active....
MSA;
is there a particular parameter you want to see? right now i got the paper copy of the PMC.
Tags
fanuc 0itb, ftc-20, interlock
510C-II door interlock Jsheldon Mazak, Mitsubishi, Mazatrol 2 07-08-2011 03:30 PM
Please help-door interlock em322 Okuma 3 01-19-2010 02:54 PM
Door interlock bypass? gearsoup Mori Mills 6 12-09-2008 12:25 AM
Door Interlock hatchmar Fanuc 5 12-29-2007 06:52 PM
Door interlock? Edster Fadal 9 04-05-2006 05:13 PM
