Old 04-12-2011, 07:20 PM
bgrdtruk is on a distinguished road
Exclamation I don't think so but want to check anyway....
I've programed Fanuc controls for a while now and I was asked a question the other day by a new guy that ran Okuma's before. He asked me if Fanuc's could run "subs" that are attached to the bottom of the main program like Okuma's can.
One reason I ask is we were running a program using a standard sub and the control would hesitate when switching between the main program and sub. When we run a sub that repeats (M98 P1000 L20) it also hesitates.
I think the hesitation is because the control can't read fast enough to make a reasonably smooth motion but that is just my guess. I was thinking that if the control would allow a sub in the main it would not hesitate as much.
Steve
Old 04-12-2011, 09:26 PM
dcoupar's Avatar
You can use M99 Pnnnn in a program to "jump" to a sequence number in the same program.
If your control has the Custom Macro option, you could add a counter and an IF statement to exit the branch when the counter reaches 21.
I'm not sure how much faster this would be, however.
Old 04-12-2011, 09:36 PM
tc429's Avatar
tc429 is on a distinguished road
I never tried, but theres parameters that set non-bufferred m codes- might try (carefully) with setting to 98 (and 99 for the return) and trying it. any non motion block in a fanuc results in in-position check- I think though if defined as not bufferred, might just buffer the next line(needs to be a motion block to prevent stops). I'll have to try it when I get a chance too
Tim
Old 04-13-2011, 01:17 AM
sinha_nsit is on a distinguished road
I believe, the sub/macro has to be a separate program in Fanuc.
Old 04-13-2011, 07:15 PM
christinandavid's Avatar
christinandavid is on a distinguished road
If you can use macro b on the control, and if it is suitable for your needs, I find a repeating WHILE, DO loop to be quicker than IF, GOTO.
DP
Old 04-14-2011, 11:52 PM
That is true.
I actually verified it with a stop watch some time back.
The reason perhaps is, GOTO has to search all the sequence numbers, whereas WHILE_DO_ loop is fixed.
Spell check it out!!! I just noticed CNCzone now has spell check! HayTay CNCzone Club House 3 01-19-2007 07:59 AM
Check Out ! vijaychd General CAM Discussion 0 05-31-2005 12:24 PM
Check out !! vijaychd Product Announcements & Manufacturer News 0 05-31-2005 11:14 AM
Check this DRO Konstantin General Electronics Discussion 0 05-02-2004 11:41 AM
