Old 04-09-2011, 07:17 PM
Jfrahm is on a distinguished road
Finicky drive
Recently bought a tornos screw machine. Has Fanuc ott controller and c series drives. Just got it fired up yesterday and have a problem. The drive for chanel one alarmed out. Checked drive and no led, channel 2 ready, checked power to drive and is 203 v, checked fuses seamed ok swapped fuses between drives and it came on with led #2 low dc voltage. Pulled fuse looked at it ohmed it put it back in and drive fired up. Zeroed machine and every thing seemed ok, shut off and restarted again everything ok.Now today fired up and same thing. So I see what looks like a power supply in the middle of the drive. so is there any other fuses or connections to look at and is 203 the proper voltage at the drive.
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
Clausing Lathe Conversion, direct drive or reduced drive Marty_Escarcega Stepper Motors and Drives 0 03-16-2010 10:43 AM
Need Help!- Direct Drive Plasma - Motor/drive/power supply? CPierce18 CNC Plasma and Waterjet Machines 1 02-05-2010 05:53 PM
Need Help!- Direct Drive Plasma - Motor/drive/power supply? CPierce18 Stepper Motors and Drives 0 01-29-2010 01:01 PM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
