Hi, I am looking for a way to 'run' a 18i-MB without any amplifiers just for training. This would bring up the need for dummy axis X,Y,Z,A and B. Could this be possible or is it just one of my weird ideas ? Thanks Uli |
| Ok, so I am really starting to get frustrated. I want to play TR underworld on my macbook pro 15 inch but it keeps saying. Failed to initialize Direct 3D with current settings. |
__________________ *********************************************************** *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~* *********************************************************** *__________If you feel inclined to pay for the support you receive__________* *_______Please give to charity http://www.oxfam.org/en/getinvolved_______* *********************************************************** |
| Hi Sinha, I tried to do so, but I never see any path or workpiece in the graphics window. I admit that I am not used to these controls so maybe I just did not find the clue how to activate it. Maybe I'll try first with a full setup with amplipiers and start reducing the environment when I had success with the graphics. Just to avoid basic configuration faults. @janejoj786 and MysticMonkey: What are you talking about ? This is not to be related to this thread, is it ? Uli |
| Hi Sinha, I dont have a MDI panel because may system is an openCNC. The MDI keys are softkeys on the Screen Display Function application. There is a graph key and I get into the graphics screens, but there is no display of the path. There is an EXECUTE softkey and behind this one I can select AUTO or RUN, but no action occurs. I tried to adjust parameters like colors etc. but no change. Uli |
| OK, that's what I need to do next. For running a program, I need however to install first the amplifiers. This brings up the need for a 400V line down to my room because I can't do the testing in a workshop right now. It will take some time.... Thanks Uli |
#10
| Hi Sinha, after installing the amplifiers, the graphics work fine. However, it seems not to work without them. In the Servo Motor Parameter Manual I found a section 'Serial feedback dummy functions' with some details of dummy axis. I'll try to move forward on this path. Thanks Uli |
#11
| Toolpath plotting without actual tool movement is referred to as "Dynamic Graphic Display" by Fanuc. They offer it as an option. However, even without this option, one can execute a program in "Program Test Mode" for a similar result. |
| Bridgeport Interact 2 -- tachometer mode vs. voltage mode? | ichudov | Bridgeport and Hardinge Mills | 2 | 06-28-2010 01:24 PM |
| New Machine Build- spline mode nurbs mode | cooltool | CamSoft Products | 4 | 03-10-2009 02:03 AM |
| What is - Torque Mode? Position Mode? Speed/Velocity Mode? | sunmix | Servo Motors and Drives | 25 | 10-26-2008 03:53 AM |
| HAAS LATHE Graphics Simulation MODE | DEAN | Haas Lathes | 4 | 11-18-2007 09:45 PM |
| Simulation only ? | patrickb | FeatureCAM CAD/CAM | 4 | 05-27-2006 08:01 AM |
