Old 04-07-2011, 07:31 PM
plifter365 is on a distinguished road
367 C-Axis Counts Missed INT
Having problems with the servo spindle drive on a mill. The following spindle error occurs at start-up:
In diagnostics 200FBA , 201 AID, and 202 RTA are all one.
This spindle is being run open loop so there are only the following hooked to the motor in the J-Bax
3-phase power for the controller and fan
2 leads for temperature
The drive for this motor has already been replaced, and the motor has been checked for shorts in the windings, power, and encoder.
Everything points to an encoder fault, but this is odd considering it is being run open loop.
Is there anything in the controller that could have been changed to switch the system so it is looking for a closed loop system? I believe it is a 16i controller. Any ideas are appreciated!!
Thanks!!
Newbie- Loss of encoder counts ¡ ¡ molocas Gecko Drives 1 01-30-2012 08:02 AM
motor step counts functionbikes Automation Technology Products 2 07-27-2009 10:37 PM
Your opinion counts Janos Haas Lathes 15 11-08-2007 12:25 PM
2000 line encoder = how many counts? REVCAM_Bob General Electronics Discussion 1 05-22-2007 01:00 PM
No Encoder Counts On X Axis. Y=OK murphy625 CamSoft Products 5 03-08-2005 08:20 PM
