Old 04-07-2011, 02:02 PM
GPdriver is on a distinguished road
edit inside Parentheses
I have older 0T and and 18T Fanuc, and when the operators have to change the program for the remote DNC they have to edit the whole line parentheses to parentheses. Is there a parameter that will enable them to edit just the characters that need to be changed inside the parentheses?
Old 04-07-2011, 06:39 PM
dcoupar's Avatar
I don't believe Fanuc incorporated that editing function until the 31i (first I've seen it, anyway). It's always been a PITA...
Old 04-07-2011, 06:45 PM
stevo1 is on a distinguished road
I am not sure on the O or the 18 but on the 10,11,12,15 have the option to copy either a word or to the EOB and you can edit what you want and then press alter. This is the only editing option that I have used. Other wise as Dave stated it is a PITA.
Some other controls you could put a ( at the beginning of the line and it would let you edit thru 1 letter at a time. Then delete that (. This was on some Hitachi's I had.
Stevo
Old 04-07-2011, 08:20 PM
beege's Avatar
beege is on a distinguished road
IIRC, if you have purchased the "extended programming" option on a FANUC, you can copy the comment to the buffer, and edit the comment in its entirety using the cursor keys for editing position.
Old 04-08-2011, 07:28 AM
dcoupar's Avatar
Hey Beege,
I've just looked through "Extended Part Program Editing" descriptions in the Descriptions and Operator's Manuals for the 0 and 18 controls. They mention nothing about copying/editing in the buffer. If you know of a way, it sure would make life easier...
Old 04-08-2011, 11:18 AM
beege's Avatar
It's been 15 years, but I'm sure I remember it being on my 11M
Edit / copy / to buffer
or something like that. Deserves some experimentation, just to see if its an undocumented thing, but I don't currently run anything with extended editing.
Need Help!- inside miter ro7all WoodWorking 0 06-13-2010 03:22 PM
Parentheses on 16t controller rmailly Fanuc 3 05-09-2008 12:25 PM
Using Parentheses.... Bluegillman General Metalwork Discussion 0 04-01-2008 09:13 PM
Using Parentheses.... Bluegillman Teachers Hang out 0 03-29-2008 11:23 PM
What's inside this box? Bloy2004 General Electronics Discussion 3 04-07-2004 09:07 PM
