04-06-2011, 11:05 AM
Fanuc 10t lathe, Z position is double, which parameter to change? | | On my Hitachi-Seiki Lathe, with a fanuc 10tf controll. When I put a dial indicator on the carrige, the X axis reads correctly, by that I mean when I crank in .010" on the handle, the carrige moves .005" which would be correct as it is cutting 2 times the radius of the part. Problem is that the Z axis does the same thing, if you move the handle .010", the carrige moves .020 in the z direction, so it is double what it should be. I suspect it is in the parameters between 1000 and 1200, but not sure which one to look at.
Also, I have been trying to figure out how to use the G54 positioning and offsets of this controll as I am not used to it. I have been using a G50 Positioning for each tool, like the old 6t's used to have to use, but it sure is a pain this way. |
