Old 08-15-2005, 08:46 PM
CBMach is on a distinguished road
GN6 Series Fanuc Controller
Hi
I have VMC with GN6 Series Control.( Just buy used Machine)
All Fuction seem work OK via MDI mode.
I can not run from memory or Tape ( BTR )
In X,Y,Z position screen. Is does not show Program No, and Line No ,that being execute. Right?
In Edit Mode.
I can key in the G code. After few line done. I switch to Memory mode.
screen does not show the program that just key in.
Some old program can call on EDIT mode. But also not show when switch to Memory mode.
I can Do tool change on MDI mode. ( M20 = Tool out, M23 Tool In Etc )
But It not Work On T command and M6 )
Some one can help me or any suggestion will be appreciated.
Thanks for All
