Results 1 to 7 of 7
Thread: FANUC 18iT, locking the work shift value
    Mar 2011
    Finland
    Question FANUC 18iT, locking the work shift value
    I'd like to lock the value of work shift EXT X (set to the turning center of the lathe) so you couldn't change it by accident. I think this is done with the help of machine parameters but how?
    Registered dcoupar's Avatar
    Mar 2003
    I couldn't find a parameter to lock out modification of individual axes for either work or shift offsets. My guess is if there IS a parameter, it would lock both X and Z.
    I believe you could put a G10P0X0 at the beginning of each program to ensure the X Work Shift is set to 0.
    Dec 2003
    How is your lathed homed right now, i.e. value of X at machine home?
    Is it Machine zero position you wish to change?
    Some set ups enter the machine home position distance based on the tool post face at turning centre, the tool offsets can be entered as usual.
    This would be done automatically by the parameter value being plugged in when homed.
    Mar 2011
    Finland
    dcoupar understood what I'm talking about (and I take the blame for those who didn't - English isn't my mother language, sorry). If anyone knows the right parameters for preventing the change of work shift values please let me know.
    Dec 2003
    I misunderstood.
    Generally with Fanuc the lockout is done by four hardware memory protection key inputs.
    In most cases the MTB will enable all four with one key lock switch on the panel.
    But it is possible to differentiate between all four by separating the inputs.
    The four are:
    KEY1 Enable the entry of tool comp and work zero offsets
    KEY2 Enable the entry of Setting data user parameters and macro
    KEY3 Enables the edit of part program
    KEY4 is system dependant and I am not sure what it is on the 18i
    A concealed switch could be wired in the control enclosure and input to Key1.
    Registered viorel26's Avatar
    Jun 2007
    Romania
    Param 3290
    That is what were looking for?
    Mar 2003
    Quote Originally Posted by viorel26 View Post
    I believe that setting these to 1 will disable the setting of both X AND Z work shifts from MDI. MRPM only wants to disable the X.
    Here's another thought (see attached). From the way I read this, if you set 3134 X = 0, then if there's a 0 value in the offset, it won't be displayed. I've never tried this, however, so no guarantees.
    Attached Thumbnails Attached Thumbnails FANUC 18iT, locking the work shift value-f18i_workpiece_coordinate_shift_screen.jpg
    1. FANUC 18iT, muting the lamp
      By MRPM in forum Fanuc
      Last Post: 04-07-2011, 04:52 PM
    2. FANUC 18iT, G41/G42 and G71/G72/G73
      Last Post: 03-26-2011, 03:32 PM
    3. Replies: 2
      Last Post: 03-26-2011, 12:32 PM
    4. FANUC 18iT, tool measuring
      Last Post: 03-26-2011, 08:20 AM
    5. Fanuc 18it Control problem
      By Wjman in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 11-19-2003, 01:41 AM
