Results 1 to 3 of 3
Thread: FANUC 18iT, backing up the machine parameters
    Mar 2011
    Finland
    Question FANUC 18iT, backing up the machine parameters
    Is it possible to send the machine parameters (all of them at once) from the CNC to a PC and if it is how do you do it? I can send NC-programs both ways so at least there's a connection for doing this.
    Sep 2010
    Quote Originally Posted by MRPM View Post
    1. Select the EDIT mode or set to Emergency stop.
    2. To select the parameter screen, press the SYSTEM function key as
    many times as required, or alternatively press the SYSTEM function
    key once, then the PARAM section select soft key.
    3. Press the [(OPRT)] soft key to display operation select soft keys, then
    press the forward menu key located at the right–hand side of the soft
    keys to display another set of operation select keys including
    PUNCH.
    4. Pressing the [PUNCH] soft key changes the soft key display as
    shown below:
    [ ] [ ] [ ] [CANCEL] [ EXEC ]
    5. Press the [EXEC] soft key to start parameter output. When
    parameters are being output, “OUTPUT” blinks in the state display
    field on the lower part of the screen.
    6. When parameter output terminates, “OUTPUT” stops blinking. Press
    the RESET key to interrupt parameter output.
    Regards,
    Bill
    Mar 2011
    Finland
    Thanks again Bill. You're the best!
  1. Backing Up Parameters? (OSP700L)
    By H234 in forum Okuma
    Last Post: 04-14-2012, 03:28 AM
  2. FANUC 18iT, G41/G42 and G71/G72/G73
    By MRPM in forum Fanuc
    Last Post: 03-26-2011, 03:32 PM
  3. Need Help!- Backing up Parameters
    By wganders in forum Daewoo/Doosan
    Last Post: 01-07-2010, 02:18 PM
  4. backing up parameters
    By robinhood2b in forum Bridgeport and Hardinge Mills
    Last Post: 09-30-2009, 10:31 AM
  5. Replies: 3
    Last Post: 02-03-2009, 11:40 AM
