Old 03-31-2011, 08:37 PM
madmaxx42 is on a distinguished road
FANUC OM Z IN PROGRAM CHECK NOT ABSOLUTE
WE HAVE 2 SUPERMAX VERTICALS
IN THE PROGRAM CHECK SCREEN DISTANCE TO GO PAGE ON ONE MACHINE,
IN THE ABSOLUTE COLUMN THE X AND Y ARE ACTUAL POSITION WITH RESPECT TO THE G54, BUT THE Z IS FROM MACHINE HOME OR THE TOOL LENGTH OR SOMETHING.....
IN THE OTHER MACHINE THE Z MATCHES THE PROGRAM....IF IT SAYS DIST TO GO 0.... AND THE PROGRAM IS GOING TO Z 1.0 THEN THE ABSOLUTE COLUMN ON THE DISTANCE TO GO PAGE SAYS Z1.0
IS THERE A PARAMETER THAT CAN BE SET TO CONTROL THAT
THANKS
Old 03-31-2011, 09:46 PM
dcoupar's Avatar
I would compare parameter 0018 bit 5 between the 2 machines.
Fanuc 18i - Zero the absolute scale CaseyCAM Fanuc 12 03-22-2010 05:45 PM
Need Help!- Check Program Ashish B CNC Machining Centers 0 01-03-2010 03:26 AM
Need Help!- PROGRAM CHECK FANUC O-T Daniel Boone Fanuc 6 11-08-2009 10:28 PM
Fanuc 0i-MC absolute arc center PinnacleMachine Fanuc 5 08-07-2008 10:52 AM
Program Check guypb Haas Mills 0 02-14-2008 12:39 PM
