Old 03-29-2011, 09:11 PM
blakemachine is on a distinguished road
Turret will not index as per commanded.
Ok, so on a Lathe I got with a Fanuc 10t on it. The parameters were lost. I got parameters from a so called identical machine, and loaded those, Here is the problem:
When I hit turret index, it indexes Two positions. I belive this is because there is an orfice in the solinoid, and it is going so fast that it cannot catch on the slow down switch? I belive someone took the restrictor out of this orfice?
Also, whe I command a T0100, it will just advance one position, no matter which tool it is on. So you can just keep comanding T0100 and it will just keep advancing one position.
But if I comman a T0200 or any other number, T0300, T0100, etc. It will just keep spinning the turret, and never stop untill I hit the E stop.
I have checked in the PCDGN page, and the manual shows that it is on x000, and the numbers do change in those bits, so I know the encoder on the back of the turret is working.
I belive I have a parameter wrong. Does anyone know which parameters to look at?
Old 03-30-2011, 01:54 AM
saghirecho is on a distinguished road
I think that the prblem is appearing in wiring or encoder section u can again load your codes.
saghirecho@yahoo.com
Old 03-30-2011, 06:52 PM
tc429's Avatar
tc429 is on a distinguished road
did you go in on the PC side and check the timer/counter/data table (and data)/and the keep bits? it kinda sounds like maybe theres a counter that cant exceed 1
Sl-10 Turret Index concerns Mr.Xtreme Haas Lathes 5 02-02-2009 11:43 AM
Need Help!- LNC-8C (Cadet lathe) turret index Voss_Machine Okuma 5 01-26-2009 10:15 AM
Turret index speed DocHod Servo Motors and Drives 0 03-06-2008 09:24 PM
Fanuc 18i Turret Index limitation? (need help) mcash3000 General CNC (Mill and Lathe) Control Software (NC) 1 05-03-2007 08:14 PM
Turret Index Only Once In Auto rajesh_1355 Fanuc 1 01-28-2007 05:48 PM
