Old 03-25-2011, 12:35 AM
qmas99 is on a distinguished road
Parameter of machine's Z
When we take tool length offset and use INPUT C button, we will have Relative's Z, what parameter do I need to change to get machine's Z when using INPUT C?.
Old 03-25-2011, 03:40 AM
dcoupar's Avatar
As far as I know there is no parameter to change that. You should zero out the Relative position display before setting tool length offsets.
Old 03-25-2011, 08:25 PM
I think there is, because we have Enshu EV450 can take machine's Z,it doesn't add or subtract the Z value already in the work offset.
Old 03-25-2011, 08:34 PM
dcoupar's Avatar
On the Enshu, do the Machine and Relative position displays agree? What model control are you having the problem with?
Old 03-25-2011, 08:58 PM
all the machines have Fanuc 18i, on the Enshu doesn't matter what the Relative Z is, always use Machine Z for TLO when INPUT C is pressed.
Old 03-26-2011, 12:20 AM
dcoupar's Avatar
Here's the section from the 18iM Operator's Manual on Tool Length Measurement using [ INP.C ]. Please note step 8 on the 2nd page.
I have also done a search of the Parameter Manual pdf, and find no reference to a parameter to select the Machine Position rather than the Relative Position when using [ INP. C ]
Need Help!- Machine's parameters for a BP Series II Interac 2 with a TNC 151 FELMAR Bridgeport and Hardinge Mills 4 02-16-2011 04:34 PM
Calculating my CNC machine's resolution? Robotics Guy Mechanical Calculations/Engineering Design 1 05-01-2010 03:31 PM
Max cutting depth - protecting my machine's bed craigspc Machines running Mach Software 2 08-31-2008 06:07 AM
Machine's DOWN any ideas Clawsie Machine General Metal Working Machines 9 11-22-2007 07:23 AM
how to send machine's parameter to pc nabil_elbadri G-Code Programing 2 11-14-2007 04:53 AM
