Old 03-24-2011, 10:29 PM
blakemachine is on a distinguished road
Can someone look to see why this code doesnt work for a 10tf fanuc?
Ok, I got my Hitachi Seiki lathe up and running now, and am able to send code to the machine. I sent this code, but it does not work.
O0000
G20
G0 T0101
G18
G97 S3600 M03
G0 G54 X-.0136 Z.0882
G50 S3600
G96 S200
G99 G1 Z-.0118 F.01
X.6993 Z-.4588
G18 G3 X.713 Z-.4783 R.0313
G1 Z-.9734
X1.3595 Z-1.2583
X1.5009 Z-1.1876
G28 U0. V0. W0. M05
T0100
M30
First thing is that it just turns the turret one position, each time you start the program, rather than going to the same tool every time.
Next thing is that everytime it gets to this line
It just goes idle, the cycle start light is still on, but it doesnt move, and just stays.
Any ideas on what I should modify in the post? Does the 10 accept a G18 code?
Old 03-24-2011, 10:57 PM
tc429's Avatar
tc429 is on a distinguished road
are your g54 presets ok with those numbers? not sure if you tell it to move past a stroke limit if it will go or not...what is 'distance to go' on the position screen?
on the turret moving one station, I'd look to see the pc parameters are set right...like a 8 station turret probably has a 8 station counter or data table or something- if its set to zero or one, it might get a little lost ...
Old 03-24-2011, 11:45 PM
You wouldn't happen to know which parameter it is do you?
Old 03-25-2011, 01:50 AM
sanseven is on a distinguished road
wow i dont know
Old 03-25-2011, 06:52 AM
tc429's Avatar
pc parameters are dictated by the ladder- no way of knowing without seeing a printout. some machines also use a external plc- we had some hitachi seikis with a external 'seicos' plc- what a P.O.S. that was...totally unnecessary, but was hitachis way of insuring service work I guess...
Still Cant get Fanuc 10tf Control to work, Who can I get out here to help? blakemachine Fanuc 45 03-25-2011 07:49 PM
Fanuc 10TF Questions metx Fanuc 6 11-09-2010 08:08 PM
TurboCad 9 Doesnt Work on Vista Mr.Chips General CAD Discussion 0 09-07-2008 12:15 AM
fanuc 10tf morris Fanuc 0 04-17-2008 10:20 AM
HAAS RS232 doesnt work - random errors GITRDUN Computers and Networking 6 10-19-2006 09:39 AM
